are softail and dyna breathers the same??
What exactly do you mean by "breather"? I'm fairly certain the throttle bodies are the same size so if you mean will the a/c backing plates interchange, yes. If you're referring to the breather tubes, I'm not sure.
I put a stock (not Stage 1) 08 softail Crossbones a/c unit on my 07 Street Bob. Had to get the CB breather tubes ($10) - they're longer than the Dyna ones - and one new gasket but otherwise a bolt on.
