adjusting shifter?
adjusting shifter?
is this an easy adjustment to make? i'm having to lift my heel to point my toes down to get under the shifter when upshifting. starting to get a little annoying, haha. looking at it, it appears i should be able to loosen the nut, adjust the shifter up and re-tighten. but before i loosen anything i figured i better ask if this is the correct way to do it... here is a pic to better explain what i'm getting at.
brian
brian
brian
brian
You're just missing one step.
After you loosen and remove the nut (actually a bolt) you have to pull off the shifter, then replace it to the proper angle. It won't just rotate because of the splines on the shaft.
Might take a couple tries until you get it the way you want it, then replace the bolt and tighten.
mwigfield, if you can just loosen the bolt and rotate the shifter on yours then you have bigger problems than just the shifter being at the wrong angle. You have some stripped splines.
