I have a Fxdc if i change the trees to fatbob trees. I get no rake diff. What Im trying to fined out is what size spacers are needed for the wheel an caliber. If you have done this please lmk.
Search threads by WS6 Forumla for his WG conversion. His posts provide the spacer specs. Same spacers would be needed for the Bob Fat or 0 degree Wide Glide trees.
Hes using a wideglide wheel & Hub.. I want to use my dyna wheel..
It was a easy choice.. spend 500 on WG tress are buy Fatbob trees.. I got a set of chrome fatbob trees today off ebay for 109.00.. Ill post some picture as soon as they get here an its all set...
You are correct, if you use fatbob trees there is no additional rake. The wide glide/fatbob trees are 1.5" wider than the mid glide trees you are replacing, so you will need 3/4" wheel spacers and a 3/4" spacer for your rotor. You will also need spacers for your fender. I just did that mod but decided to go with a 21" wheel instead of the stock 19" wheel so still have the rotor spacer if you need it.
do you have a picture.. Im using a 21 also.. 120/70/21
