Help Primary Bolt Stripped
Yep, I got all of the bolts out of the primary except for the last one. It is starting to strip now. Of course I already drained the primary fluid.. Now what should I do. I can tell you one thing the dealer tightened those bolts way past the recommended torque. Any ideas?
jdog
jdog
RE: Help Primary Bolt Stripped
ORIGINAL: jdog12091
jdog
jdog
If it is already too far gone, try cutting a slot into it and turn with screwdriver.
Those torx heads look good, but they sure like to booger up.
mud
like mud said, last time this happened to me.i just took a flat screwdriver,put it on the bolt at about a 45 degree,then tapped on it with a hammer. it will break loose . i belive that is a #27 torx. i found a trick too, next time before you loosen the bolts... tap on the torx with a hammer. not to hard tho. once you get all this fixed,put on some anti-sieze on those threads for sure ..
This thing is in there so hard, It's not even budging. I tried to cut a notch and get a straight screwdriver in there, but no luck. Should I just bend the derby cover and break it off at the stuck bolt and then try to get that bolt out. I already am going to have to buy a derby cover due to it getting scratched up. I really don't know what to do at this point the bolt is chewed up.
thanks,
jdog
thanks,
jdog
can you get a pair of vice grips on the bolt? I used a #27 torx on mine and they were pretty easy to come out(luckily)
If you want a stock derby cover, I just took mine off today. It's yours (with the bolts included) if you pay shipping
ORIGINAL: jdog12091
thanks,
jdog
thanks,
jdog
