Rush Slip-Ons - WTF else do I need?
Old 02-15-2010 | 05:57 PM
WDHGS's Avatar
WDHGS
Default Rush Slip-Ons - WTF else do I need?
Ok, now I am thoroughly confused after a recent visit to the dealer.
I just want to add 1.75" Rush Slip-ons to a 2010 Super Glide Custom to replace the stock for a better "harley" rumble sound. At least for now, I'm not planning on adding a stage 1 kit or air filter changes or a fuel mgt system--but I guess that's the $1200 question right now...So do I need to do anything else to the bike or can I just bolt these on and roll? Will I have to worry about overheating and possible exhaust discoloration? Will I lose any real HP or torque?
Thanks in advance.
Old 02-15-2010 | 06:23 PM
SC-Longhair's Avatar
SC-Longhair
You can run just the slip-ons. Once you alter your a/c, then you will need the fuel management.
You won't lose any power but you won't gain any either.
Old 02-15-2010 | 06:28 PM
KYFATBOB's Avatar
KYFATBOB
yep just slap them on and ride.... those turn signals are awesome what are those??
Old 02-15-2010 | 06:31 PM
chester1957's Avatar
chester1957
Put em on you'll be fine, I ran my 07 with just slip ons for the first 6 months I had it and had no problems.
Note: At that time the best price was from Fuelmoto.
Old 02-15-2010 | 06:53 PM
OldFenderGuy's Avatar
OldFenderGuy
The original Screamin' Eagle 2 mufflers (the 'for off road use only' version that is no longer carried at the dealership) and the Rush mufflers are my two favorites for both sound and quality.
For what it's worth, my Harley dealership mechanic friend told me that from test results you can use 2.0" or smaller baffles in the Rush mufflers without needing to remap anything.
I'm running the Rush 2.0" Baloney Cut mufflers on my modified 2003 WideGlide. Here is a little audio/video of the mufflers at idle. I used an old Sony digital camera with build in mic so the quality isn't that great, but it will give you an ideo of how they sound;
http://dogsdoom.com/PI/2003-wd-rush-2-01.MPG
Old 02-15-2010 | 06:57 PM
tbob's Avatar
tbob
Ive had Rush pipes on the wifes Heretage for Two years with no problems.
Old 02-15-2010 | 06:58 PM
maddghost's Avatar
maddghost
Your perfectly safe with the slip-ons!
Great sound OFG , makes me want spring ever much!
Old 02-15-2010 | 07:09 PM
WDHGS's Avatar
WDHGS
That's the Kuryakyn Panacea Tailight System. The main tailight has the run/brake/turn module and flashes 6 times when you brake to get the guy behind you to pay attention and get off your ****. I also added the rear and front LEDs from them as well. They even have a video on their website to show you how to install them and the ordering process is simple. All you need is a screwdriver and be able to remove your seat--it looks even better at night. http://www.kuryakyn.com/index.cfm/go...ID/3/IMID/1588
The pic you see if of my FatBob which I just sold for a nice profit--my 2010 Super Glide Custom is waiting for Spring at the dealership. And yes, the license plate means I am a scarcastic SOB!!
Old 02-15-2010 | 07:19 PM
robanna's Avatar
robanna
You've already heard it above, but I'll add confirmation. I've had Rush slipons on my Sporty and now my Fatbob with no other mods and it's completely fine. As stated, don't go above 2.0 baffle size otherwise it may cause breathing issues.
The Rush slipons are fantastic. IMHO, I'd go for the 2.0 vs. 1.75. It's a deeper rumble on the Vtwin without being obnoxious.
Old 02-15-2010 | 07:57 PM
US66harley's Avatar
US66harley
Ran 2" rush for 3 months with no problems, then went stage 1.
Quick Reply: Rush Slip-Ons - WTF else do I need?
