Tightening the Compensator nut
WOW, I am truely floored, I'll take my BS flag now and stick it in my mouth. I have honestly never seen such a procedure in writing or practice but you guys have obviously seen technical data that stands as proof. I just am struggling to embrace that idea, do you realize how much variance that can allow, from one person to the next. Does sound like though that procedue might be prior to 06 models if I am understanding this right though, sorry for any misleading on my part fellas.
Ever see the spec for tightening the headbolts on a 91 Evo. Torque to a specific value them make a reference mark on the bolt and head surface. Then (rotate) tighten an additional 90 degrees. Dumbest spec I've ever seen. James gaskets give a proper torque spec and sequence,
Dumb it is not, this process has been used for at least 60 years on jet engines...and many other types of high tech machinery.
It is a much more accurate way to determine the amount of tension there is on a fastener.
I know this is a long dead thread, but I couldn`t let this one pass....
Yeah, me too. It's called "torque to yield" and is much more precise than just cranking it down until the wrench clicks. In fact, the tighter you have to go the more precise it gets as you are minimizing the effects of friction between the parts.
The fact that a fastener is torqued to degrees does not mean it is a torque to yield fastener, lots of fasteners that are torqued to degrees are not torqued to yield, and are reusable.
Obviously you do not understand the process..
As a former tool and die inspector who also measured the flatness of gauge blocks to within a few angstrom units (one ten-billionth of a metre) I understand the process. If the process is so much accurate, why is there no tool available to measure it.
So you can eyeball exactly 90 degrees? There is no tool from HD to accurately measure this.
DutchJo (03-02-2023)
If you can`t figure out 90 degrees you are in trouble, it is simply a quarter turn.
I'd go with the manual personally. If HD wants to update their manuals for this value they need to make their consumers aware of it by a SB, TSB, EA or something. I would then ask how the tech came about that calculation for your particular year, model, ect.
And further more, I'm a mechanic by trade also, and in my twenty years of wrenching, I've torqued an astronomical amount of fasteners, whether on cars, trucks, motorcycles or mostly jets, and I've have never heard of a mfg calling out a torque like that. Even in aviation I have come across numerous specialty tools digital protractors, inclinometers, but none are used for load or bearing seating (ie, torque). Your calculation of 40 deg in addition to mfg torque = 200ft pounds, maybe, your calculated eye might be different than my calculated eye, and that's the biggest reason I would shoot this down and say BS.
