front fender from KC International
Old 02-10-2010, 09:06 AM
8541hog's Avatar
8541hog
8541hog is offline
Looks like a narrow variation of the fender I have on the front of mine, I bought it as a blank like that as well. It has been on mine for almost 5 years and no issues whatsoever.
Old 04-25-2010, 01:09 PM
zss42002's Avatar
zss42002
zss42002 is offline
i have a 07 softail nighttain and looking to buy one form them on ebay just wondering if comes with any spacers or do i have to buy them or make them?? also how are they quality wise??
Old 04-25-2010, 02:02 PM
sniper77's Avatar
sniper77
sniper77 is offline
A 5.5" wide fender is much better for clearance. I used a 4.75" fender and have to remove the fender to get the tire out, not an easy job.
The first fender I bought I had to send back because the radius was too tight to clear the tire (100/90-19) and there was no way a 21" of any width would have fit under it.
I ended up buying from mid-America but think the fender is identical to the one pictured on the link provided above.
Old 04-25-2010, 02:17 PM
zss42002's Avatar
zss42002
zss42002 is offline
what size spacer did you use and how much longer of a bolt did you have to buy?? will the 5.5" look funny?? also whats the easiest way to measure and drill for the fender bolts?? how much clearance should i leave between the tire and fender
norcal
02-21-2014 06:11 AM
nightrain1983
05-29-2013 03:35 PM
DarkRock
05-07-2012 08:38 PM
low_n_slow
05-30-2009 08:17 PM
ape.hanger883
03-07-2009 08:51 AM
Quick Reply: front fender from KC International
