V&H ShortShots Baffle or no Baffle?
You can change them with the pipes mounted. I have the V&H shortshots but with the "quiet baffles" in. Nothing "quiet" about them, but they give the nice, deep Harley rumble. Not obnoxious if I go out easy on the throttle in the morning, but they'll bark if I crack that throttle! I haven't heard the BCT baffles, so I can't compare the two or suggest which is better.
i have v&h short shots on my fxdc and they are loud! yes they pop and are generally obnoxious, car alarms seem to follow me.
they come from V&H with a baffle and they offer a "quiet" baffle for 30 buks each. i started out with the stock ones and added the quiet version later. they are both loud, WAY loud!. i use ear plugs, gotta admit i love the sound even plugged. but the guy who mentioned another provider for baffles, was that for v&h? link me please
Like many have already suggested go for the Big City Thunder Monster baffles. The sound is incredible. You will be able to install the baffle when the pipes are on the bike but you will likely have to remove the heat shields as the set screw that holds the baffle in place is usually tough to get at with the heat shields on.
I just took the heat shields off with the pipes on the bike, didnt see a need to remove the whole pipe, then the shields from the pipe, the reinstalling both.
But I guess that depends on where you want to put the set screw
Short shots are LOUD. I ran mine w/out baffles for about 1 mile and it ran like AS$ and sounded that way too!
not being able to adjust a carb to make it run right is my only issue.
I think i will try it anyway.
it doesn't really matter though, because i have to ride it around the barn to test the sound (acoustics aren't so great in there)... this snow storm is killing me!
You need to measure the inner diameter of your pipe to know exactly which baffle to order. Here is the link to the BCT baffles. https://bigcitythunder.com/shop/shop...categories.asp
I will be installing a set of these soon!!!
