Dropping the rear FXDWG question
Old 02-06-2010, 04:00 AM
Jeff W's Avatar
Jeff W
Jeff W is offline
Default Dropping the rear FXDWG question
I have no idea what to expect so i ask those who would know, If i dropped the rear end on my Wide Glide, how does this effect handling? or does it effect the handling any?
Old 02-06-2010, 08:00 AM
Romark's Avatar
Romark
Romark is offline
I lowered mine about an inch. No difference that I can tell.
Old 02-06-2010, 09:19 AM
rounder's Avatar
rounder
rounder is offline
barely have an effect. although it will depend on how you lower the bike. If you choose say 11.5" works shocks to lower it, you will get a better ride and added stability so you handling will improve although your lean angle gets reduced a little.
Old 02-06-2010, 10:00 AM
speedkills's Avatar
speedkills
speedkills is offline
how do lowering blocks affect ride quality compared to using shorter springs like the 11.5s?
Old 02-06-2010, 11:00 AM
rounder's Avatar
rounder
rounder is offline
they change the angle of the shocks thereby reducing the spring rate. So they end up softer, most will just add 1 click of preload to em so the ride about the same as before. Of course the only ride you will get is the ride the stock shocks can give you. the angle change will have an effect on use of saddlebags.
Old 02-06-2010, 02:26 PM
Jeff W's Avatar
Jeff W
Jeff W is offline
So id be better just going with the 11.5" works shocks and skip the blocks, but i could go either way with little to no effect on handling, correct? now is that the same shocks and just change the springs? or complete change. Bear with me, im an old auto mechanic but this Harley is a learning experience. And thanks for the replies!
Old 02-06-2010, 02:29 PM
Jeff W's Avatar
Jeff W
Jeff W is offline
Oh yes, do you happen to have a link, i am sifting through sponsors but i dont know if they are a sponsor here. Sorry to ask so much of you.
Old 02-06-2010, 06:17 PM
BamaBoyjc's Avatar
BamaBoyjc
BamaBoyjc is offline
I read in another thread the stock 2010 WG shocks are already 11". I measured from mount hole to mount hole and it's almost 12'. am I wrong?
Old 02-09-2010, 06:55 PM
Tripwire1's Avatar
Tripwire1
Tripwire1 is offline
Jeff W,
I would not mind lowering the rear fender to decrease the space between the tire and fender but would like to keep the ride height. Is this what you are trying to achieve? Not to high jack your thread but if anyone knows how to best accomplish please PM me. Regards
Cruzn34
05-20-2013 04:09 PM
Krazy8s
02-05-2013 07:13 PM
Ben E
02-16-2012 05:45 AM
hotrod351
EVO
09-07-2008 11:09 PM
sprinter
04-13-2005 01:21 AM
Quick Reply: Dropping the rear FXDWG question
