2 into 1 exhaust VS drag pipes
Old 05-28-2005 | 02:32 AM
kata's Avatar
kata
Default 2 into 1 exhaust VS drag pipes
did anyone knows what the difference (performance-vise) would be between a 2 into 1 and some drag pipes (l want black exhaust and l can't find a decent blacked out 2into 1)
Old 05-29-2005 | 07:06 PM
pococj's Avatar
pococj
Default RE: 2 into 1 exhaust VS drag pipes
If you want drags, here's a li'l something that'll help.
http://www.vtwintalk.com/m_5286/tm.htm
Old 05-29-2005 | 10:42 PM
kata's Avatar
kata
hey great info thanx a lot, l haven't even thought about the legal aspect, so l guess that 2 into1 kinda' looks like my way out huh ?
thanx again man
Old 05-30-2005 | 03:42 PM
pococj's Avatar
pococj
ORIGINAL: kata
thanx again man
Don't know where you live, so the legal aspect of it may not need to enter into your decision at all. Besides, I just read about something up MA way about the cops voluntarily testing guys' pipes. None of the aftermarket pipes passed the tests. Zero, nada, zip. Only way to pass the tests was to have completely stock pipes.
My solution? Run what ya want, but behave yerself in town!
Old 05-30-2005 | 10:15 PM
kata's Avatar
kata
l live in northern VA and l think that here besides S-CA are the most strict rules, even l haven't seen a biker pulled over yet....
thank you for the imput.... l hate chromosexuals too ('chrome won't get ya home')
Old 06-03-2005 | 11:39 AM
HDF Tech's Avatar
HDF Tech
kata
The difference between the two are at opposite ends of the perfomance scale. The drags are basically meant for just that (drags), where as a 2 into 1 will scavenge your engine and give you more power. Drags are not a performance "enhancement" but a good 2 into 1 IS
Old 06-03-2005 | 02:32 PM
Tripper's Avatar
Tripper
Kata, have you thought about buying chrome then using black exhaust wrap? I don't know what the reletive pluses and minuses are of doing that but it is worth considering if you can't find a blackend 2 into 1.
Old 06-03-2005 | 02:46 PM
grimm's Avatar
grimm
For performance? Definitely a 2 into 1. Thunderheader makes some that are black. If you don't like those, there are shops out there that do black ceramic coating. It's not too expensive either. I'm going to be getting my shortshots coated for about a hundred bucks.
Old 06-03-2005 | 03:58 PM
Tripper's Avatar
Tripper
Find a pic at http://www.richproductsco.com/1026bc.htm
Old 06-16-2005 | 02:49 AM
mrbriang's Avatar
mrbriang
the only pipe to look at would be the thunderheader !! available in black ceramic coat. runs great sounds even better !!!!!!!
nothing better than a header. thunderheader.net
Quick Reply: 2 into 1 exhaust VS drag pipes
