Why wont my darn bike start???!!
So tonight was another makeover for the bike, putting on the nash drag bars. Got everything on, but for some reason, I keep blowing my 15A Fuse, and that fuse is the ignition fuse. I dont know why but I get power to everything else, Im just losing that fuse, Ive already used two and both have blown. what the F?? Assistance please!
Here are some crappy pics from the phone. What ya'll think? Prefer these or the 12 inch apes before?
That must be it, because I had to drill the holes/rectangles myself to fit the internal wiring, so I may have not made it large enought and it could be pinching the wires. I had checked for that earlier and the only "pinching" I saw was on the wires for the turn signals.
Would this still be causing the fuse to blow even if its not pinching the ignition wire?
if you drill or cut holes to run wires through, you might want to consider either filing them or getting some grommets. Those sharp edges can cause you some real problems either now or down the road....
down the road really sucks if you're.....well...down the road.
shortcuts = shorts & cuts :P
ok that was stupid.....
pinched wire most certainly. could be the area by the switch housing itself. Gotta make sure you can move the wires freely through the bars once run. So there should be some slack. you definitely want the holes as smooth as you can get them. also you could put some slilcone around the edging of the holes(what I did) and let it dry. that will help cover up the edges to make for a safer surface for the wires to be next to. I also recommend the wires be run through their protective sleeve or maybe double shrink wrap them or wrap good with electrical tape for lots of protection from possible problems on any edges. FWIW I pinched the orange and white wire myself when installing my bars right at the housing. Nothing to do with the holes just not careful that the wires were good and clear of the housing. this blew my battery fuse, I had no start or right turn signals because of this.
kurt84
07-11-2013 11:17 AM
