Harley Service vs Independent Service guy
My street bob is due for it`s 10k service. My question is, Harley dealership wants $ 400.00 vs an independent guy who wants $290.00.
Now Harley says it`s a 2+ hour service time and the independent guy say it`s no less than 5 hours to do all. Sooo, who is right and who is full of ****??
I have read posts on the different forums where techs have said their dealer does not perform each item on the scheduled maintenance list, just the major items. I don't know how wide spead this practice is.
I tend to agree with thorough maintenance taking closer to five hours.
I also maintain my own bike so I don't have to wonder what was skipped, or missed.
I took my bike to the dealer last year for the 1000 mile service, partly because it was fairly inexpensive, mostly because I didn't have a jack. Now I have the jack, I won't be doing that again. Not to mention, I'll feel a bit more comfortable knowing what was done and not done - and I can use the extra $$$ on the bike.
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
Save your money and buy a manual! Change engine/tranny/primary oils, check & adjust and lube all cables, check & adjust belt, inspect brakes-rotors/pads & fluid, tires/air pressure, lube jiffy stand, check motor mounts & all other critical nuts/bolts, check head bearings. About 1-1 1/2hrs and total cost for supplies including manual around $100, and gaining confidence in doing your own work, plus saving atleast $200....PRICELESS!
+1 on doing it yourself, lots of positives going that route.
however, if you've gotta take it in, i'd go to the indy.
like someone mentioned, HD has set times that each job is supposed to take, so if you bring it in you're getting a tech that's going to spend X amount of time on your bike, rather than an indy who's more likely to do what needs to be done, regardless of time.
i trust my local indy to treat my bike like he does his own, whereas i expect moco to treat it like just another customer's bike.
