Changed my headlight out for a larger 1. The new one came with a H4 50-100 watt. After I installed it and soldered the wires and turned it on my low beam looks not real bright and the blue headlight marker come on my dash board. Can't find my owners manual. What does that mean ?
desolder and swap the wires, so high beam works with blue marker. same thing happen to mine, wire colors didn't match. also check ground connection, might be loose.
Ok its for the high beam indicator.... kinda feel dumb. When I start the bike the blue light is dim and my low beams don't seems to be bright. I hit the high beam switch the blue light brightens and the high beam is great lots of intense light
Don't feel dumb, I did the same thing. I had to extend my wiring for the new bucket and got the low beam wiring switched when I connected everything back together. Switched the 2 around and all is good.
