6 speeds
Old 07-22-2006, 10:12 AM
propkillr's Avatar
propkillr
propkillr is offline
Default 6 speeds
i just put my 07 eg standard in the garage. any of you 6 shooters have a sound like a loose chain in 5th gear? i was able to put 130 miles on it and 5th gear does a lot of wining. i hope 500 to a thousand miles will be what she needs.
Old 07-22-2006, 10:15 AM
jaysonL's Avatar
jaysonL
jaysonL is offline
Default RE: 6 speeds
NO, mine just had the 1k mile service, and is as tight as a drum.
Old 07-22-2006, 02:25 PM
scotch's Avatar
scotch
scotch is offline
aren't 5 and 6 on a separate shaft? I would think that would make a little more noise than the non-6ers
Old 07-22-2006, 03:53 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Shovelhead Bob is offline
5th does whine a bit.....
Haven't heard that before 'cept occasionally 4th on a 5 speed....
Not all that often....
Think that it might have to be the back cut gears... Gotta wait and see though...
Old 07-24-2006, 05:50 PM
misfit's Avatar
misfit
misfit is offline
I think that 5th & 6th are on the mainshaft, but 1st & 5th are both spur gears. Maybe that is why they whine? I have 5200 miles on my 06 SG and I still get the 5th gear whine and a bit in 1st as well. It's only those two though and the only reason I could come up with is because they are both spur gears. The bike still runs great, so I'm not sweating it.
Old 07-24-2006, 05:52 PM
Psycho's Avatar
Psycho
Psycho is offline
Mine sounds like it's going to come apart in fifth gear. I just ride the heII out of it anyway. If it comes apart, it comes apart.
Old 07-24-2006, 06:20 PM
JamieWG's Avatar
JamieWG
JamieWG is offline
Mine sounds the same no matter which gear I am using. But it's kinda hard to hear over the pipes anyway.
Old 07-24-2006, 11:34 PM
06dynablack's Avatar
06dynablack
06dynablack is offline
propkiller its when your kinda coasting at bout 45 to 40 right that you hear it? i used too hear mine till it had few thousand miles on it dont hear it no more.just curious if you had the trans recall done yet?after recall i never heard it again
Old 07-24-2006, 11:35 PM
06dynablack
whoops my mistake see its a 07 model so no recall on trans
Old 07-24-2006, 11:40 PM
hd_sob's Avatar
hd_sob
hd_sob is offline
ORIGINAL: Psycho
I wonder what mine sounds like? No helmet + No windshield = I can't hear JACK...
Quick Reply: 6 speeds
