Wraping Pipes
Old 07-21-2006 | 08:24 PM
Mad Bob er's Avatar
Mad Bob er
Default Wraping Pipes
I plan on adding some Cycle Shack turn-out mufflers to my Bob, and want to wrap the header pipes. Has anyone wrapped over the heat shields of the stock pipes? Any help is appreciated.
Mad Bob er
Old 07-21-2006 | 09:53 PM
WgSkee's Avatar
WgSkee
Default RE: Wraping Pipes
Mad Bob er..... Welcome Aboard.. Do a search in the forums for info... wrapping the heat shields..? Here's a link on wrapping...Good Luck....Skee
http://www.bikernet.com/garage/PageV...asp?PageID=750
Old 07-21-2006 | 11:59 PM
but Ill try 2 try's Avatar
but Ill try 2 try
Take the heat shields off, then wrap. BTW, I have the CS turnouts and they are the shiznit.
Old 07-22-2006 | 12:15 AM
Mad Bob er's Avatar
Mad Bob er
Thanks for the info. I quess I will see how it looks when I get the pipes off.
Old 07-22-2006 | 02:22 AM
Tolly's Avatar
Tolly
I removed the heat shields and wrapped the pipes to the slip-ons. I really like it!
Old 07-23-2006 | 12:21 AM
khata's Avatar
khata
this what l did:
1st l sanded the chrome a bit 'couse l was gonna paint them flat black
[IMG]local://upfiles/9786/4C99953F1CAF4CA79A5C6D5BE3D8BB3F.jpg[/IMG]
Old 07-23-2006 | 12:25 AM
khata's Avatar
khata
2nd l cleaned the pipes of grease and such
3rd l've let the wrap soak for a while
4th l started wrapping them watching my spacing
[IMG]local://upfiles/9786/139CCCB75FAD4BF4ABBBEE1E8CD7BE61.jpg[/IMG]
[IMG]local://upfiles/9786/05359A6D11964EC19A875D0B66E9D254.jpg[/IMG]
Old 07-23-2006 | 12:31 AM
khata's Avatar
khata
5th on my front pipe was a dent (that's what you get at the swapmeet if you don't want to spend the whole paycheck) so l took some aluminum foil and patch it up (it works like a dream)
[IMG]local://upfiles/9786/F2A8651BC32D4E4792F56F9AAEF6FBEA.jpg[/IMG]
[IMG]local://upfiles/9786/5F3E79EBA7824498A98169757C9DA968.jpg[/IMG]
Old 07-23-2006 | 12:33 AM
khata's Avatar
khata
both pipes finished, next painting and mouting
[IMG]local://upfiles/9786/12B29DB2B154425DBE1FCCD57C4809D1.jpg[/IMG]
[IMG]local://upfiles/9786/62D67939A59C444F9606580AFCBB8DB7.jpg[/IMG]
Old 07-23-2006 | 12:37 AM
khata's Avatar
khata
mock up on the bike and fabbing the rear bracket, oo and l almost forgot i started at the end working my way towards the heads, that way it'l only need a single stainless hose clamp (cheap motherf... aren't l?)
[IMG]local://upfiles/9786/8F6FD5A5BA5B400D93C34536BF86FE6F.jpg[/IMG]
[IMG]local://upfiles/9786/092799C2610B4DA59C4F3660F8959884.jpg[/IMG]
Quick Reply: Wraping Pipes
