Forward controls on a 2010 Dyna FXDC
I was reading that some have noticed a leak from the thru-hole for the now removed shaft. Some were saying once the shaft is removed the seal in the thru-hole in time drops down and causes a leak. Has anyone experienced this?
In the pics on this thread is that a cap that was put on the primary cover after tha shaft is removed?
One more thing, that other shift-rod that you guys are using in place of the one in the kit. Is that a HD part or after market? If it's HD, what is the part #? Will it fit on an '09 Super Glide Custom?
Thanks guys...getting close to taking this on...(I research the hell out of stuff...lol)
[QUOTE=ramu3527;7350081]One more thing, that other shift-rod that you guys are using in place of the one in the kit. Is that a HD part or after market? If it's HD, what is the part #? Will it fit on an '09 Super Glide Custom?[QUOTE]
I did it on my '09 FXDC and used this from WS6 earlier post.....
"I installed the 2005 and earlier kit (P/N 49080-03A) with a longer 2006 custom polished stainless steel shift rod (P/N 33815-06) that comes with the stronger heim joints (they won't break like the original joints)."
I did not plug the hole - I just slid the mid-shifter shaft back flush with the outer primary cover. I tucked it behind the bolt and it has been like that for about 3500 miles with no problems.
If you look close, you can see my old shifter rod in the photo from the other side.
![Question](https://www.hdforums.com/forum/images/icons/icon5.gif)
What are the latest opinions on cutting the original shaft?
I put forwards on my 07 FXDC earlier this year, opting to leave the original in situ until the winter but now I see a few comments of oil leaking from the hole that is left in the side cover.
Should I do it or leave the shaft alone?
Opinions welcomed please
