Solo Seat Question
Solo Seat Question
Hi everyone, love the forum and at looking at one and alls bikes I see that the "SOLO SEAT" looks darn good.
Few questions from nooby.
1. What is the best SOLO seat that I can purchase, comfort, look and installation are a factor
2. Do you have to drill the rear fender when you install the seat or is there an existing bolt hole or something of the sort.
3. Is it easy to reinstall the old seat if wifey wants a ride to the restaurant or daughter wants to be picked up at school
4. Are JELL seats better.
Thanks people, you've been a huge help so far. Let's go for one more.
André
André
André
André
Any seat made for you bike is a simple undo the rear screw and lift the seat off for the most part. Insert seat tank 1st under the tab and screw it down at the reat mounting point. If you can operate a Large Phillips Head Screw Driver or better yet a 3/8 inch ratchet with a Large Phillips Head you should be good to go.
As for switching back and forth (Solo or 2 Up seat) you will need to get a seat mount installed in the front position in the fender (the hole is already there)
You may want to buy a Fender Rack or Fender Bib to cover the rear and fill the mount when riding Solo.
I don't know anything about Jell other than when it is cold your A$$ is also gonna be cold.
Just my input.
Karsten
either will be more comfortable than your stock 2 up seat. no holes to drill.
my sig pic has one on my bike.
I think the Mustang vintage solo seat is the most comfortable but it does sit you up a little higher because of all the padding. While it doesn't look bad at all I don't think it's the best looking seat.
The best looking solo seat in my opinion is the Lepera Bare Bones. It will sit you lower because of it's thinness but then that also makes it less comfortable.
Here's a pic of my bike with the Mustang Vintage solo seat
And here is my bike again with the Lepera Bare Bones seat
The gell will retain heat (from sun) or cold, so your rear will be hot/cold for awhile after you jump on, otherwise its OK. Some have used the airhawk cushion for more rear end comfort or have two seats, a more comfort one and a more stylish one. Plus a passenger pillon or two up seat. Easy to switch back and forth. Usually the solo and two up seats use different fender mounting holes but otherwise bolt up. So you may need an extra mounting bolt/nut kit. Bolts with larger thumb screw heads are quicker/easier to remove and install than the stock philips head bolt. The fender nuts are easy to lose, so perhaps keep extras on hand. There have been plenty of tips posted.
you have an fxdx.... instead of a solo look to get a fastback seat! much better looking on that bike.... mustang fastback, lepera daytona sport, C&C fastback. Best looking seats for a FXDX. I have a solo and pillion setup... with 11" shocks the rear was slammed and the bike looked good solo. Back to 12" shocks and I can't stand the look of a solo with the rear fender stocking up so high. The pillion is always on my bike now.
I have three of them. The stock street bob seat isn't too bad, I can go about a hundred miles on it and be fairly comfortable.
The Lepera bare bones is mostly for looks but was more comfortable then I was expecting, I can go about 50-75 miles before my back starts aching.
And finally the Mustang wide vintage solo with drivers backrest, I just ordered this one and I can't wait to try it out. It seems to be the most popular on the forums as far as comfort, I hope they are correct.
I just went through a few seat and wound up with the Mustang Classic Solo. I did not find it sat me up any higher than my stock 07 Street Bob seat. My stock seat was comfortable but I always felt like I was trying to keep my self in the seat. When accelerating I would feel like I was going to slip off the back. When hitting bumps I found I would move sideways. My arms were tired just holding on. After putting on the Mustang Seat I feel planted and now I have noticed a noteable difference in my riding comfort, much more relaxed. I really like it.
