Need some clutch help
![Exclamation](https://www.hdforums.com/forum/images/icons/icon4.gif)
I just put on some 16" apes, new hand controls, and a new Barnett clutch cable. I followed my Clymer manual to the letter in removing the side plate behind the exhaust, removing that clamp ring, the roller bearings are in their groves, the opening of that clip ring is positioned according to spec, etc, etc...
Then removed that derby cover on the primary side, adjusting the locknut and pushrod according to spec. I then made my inline cable adjustments on the cable making sure I had 1/16" of play. Filled the trans with 22 oz. of fluid.
The clutch lever action "feels" good at a standstill. Smooth tension, no binding, and it seems to be working right.
Here's the problem: Without starting the bike, If I put it in first gear with the clutch pulled, I can't roll the bike. It doesn't feel like the clutch is fully disengaging. I try to adjust it one way it is too "tight" and the lever will not pull in all the way, I adjust the other way, and it feels like there is too much slack in the cable.
I've taken everything bake apart, reinstalled it all again according to the manual and according to a few how-to videos on youtube.
It still can't roll it in gear with the clutch pulled.
Am I missing something here? I'm afraid to start it and try shifting since I don't wanna damage my trans.
Any guidance, experience, or thoughts would be much appreciated.
Not sure if this is reliable but someone told me that not being able to roll it in gear is somewhat normal. especially when it's cold and been sitting for a while. They said if I'm confident in my adjustments, I should just start the bitch and go. When it warms up everything will smooth out.
Do you guys believe this is true?
EDIT: sniper I just read your post. Thanks. So you believe it will smooth out when it warms up?
I turned the pushrod in untill I felt it start to grab. Very light tension. Then I backed it out 1/2 turn.
As several have chimed in since; it does sound like it will be fine when you fire it up. Just make sure you won't run over anything if it doesn't disengage right off.
