Burp from pipes and seafoam question.
I added about 4 oz of seafoam and took the bike out for a quick ride(no plates)so it was only about 5-10 min. then let the bike run in my garage another 10-15 min.
when i shut her down after about 3-4 seconds there was a burping sound from the pipes. i started back up turned off and burp again.
is this normal??
thanks-
is this normal??
thanks-
is this normal??
thanks-
is this normal??
thanks-
You have to run a tankfull or two to get the cleaning effects from Seafoam or any other cleaner.
Don't worry about anything until after you do that.
Thanks-
4 oz with about 4 gal of gas. i believe thats the correct amount.
Ed so i guess no harm. Im going to let the Bike sit for the next month and hope there is no problem. I figured by reading when people stored there Bikes using seafoam they put it in and ran it for a few then shut her down.? does everyone run it threw a tank-full?
Thanks-
I also use Seafoam once in a while just to clean things up (thus the need to run a tankfull once in a while).
Relax, you are good to go!
E DOGG
12-21-2006 07:04 PM
