What SE A/C part no?
I've seen some comments that the SE A/C is garbage, and a K&N filter should be used instead, which leads down another rat's nest of product numbers etc. I also see that there is a new SE A/C that just came out.
What do I need to buy for my '06 DCI? Going to using the SERT as soon as I get it.
Thanks
Thanks
RE: What SE A/C part no?
The Arlen Ness Stage 1 Big Sucker comes with a K&N element. Eastern Performance will put one on your door step for just under a HD (hundred dollers). I've seen a filter from Zipper's for even less but they don't claim the element is a K&N. Why pay a lot more for the SE kit which you have to add a K&N element to?
If you buy all the parts separately, you can get the chrome SE AC backplate, assorted screws and hardware and a KN filter for around $100 total.
You will need to order -
1. Gasket 29583-01
2. Plug, breather (2) 29557-05
3. “O”-ring (2) 11292
4. Stud, air cleaner mounting (3) 29447-99A
5. Screw, button head, 1/4-20 x 3/8 in. long (3) 3938
You will also need a backplate.. part number for the standard SE backplate is 29478-05, if you want the chrome one it is 29510-05. KN filter is HD-0800.
If you need a copy of the installation instructions, send me a PM. If the gasket is out of stock, don't worry about it. I used my original gasket with no probs.
I ordered all the parts from Zanottis. Here is a link.. https://www.zanottimotor.com/shopping/partLookUp.html
Takes about three days to get the parts. The KN filter is widely available on the web for $39. Or you can order it directly from KN for $50.
Good luck.
1. Gasket 29583-01
Good luck.
