Looking For Some Help Locating Some Parts
I just bought a 2010 HD Wide Glide stock. I made no upgrades or changes at day of signing.
Because I want to ride the bike for a while and see what I really wanted to change. After searching the web seeing others bikes
I am looking to black my bike out. I have not been able to located the following Item front forks (flat Or Anodize) and turning singles lights.
Has anyone every blacked out a 2010 HD Wide Glide. Would like to see some pictures to get ideas.
Thank you
Eddy K
Thank you
Eddy K
you will need to have the trees powdercoated unless they have no rake like the fatbob. If you have a couple degree rake, you don't want the ones Harley sells(older wideglide had rake in the trees as well as extra rake in the neck(unsure about 2010 model). Also turn signals, you just need to buy ones from a crossbones along with the standoffs, or again pull em apart and have current ones powdercoated. Another thing too, should you want an all black headlight, again you can buy the ring from a crossbones and voilla. Many parts can be taken from other bikes and used on yours.
