02 sensors trashed!!!!
Old 08-12-2007, 08:50 PM
Arcane's Avatar
Arcane
Arcane is offline
Default RE: 02 sensors trashed!!!!
I installed the T-Max a few weeks ago and I had a problem removing the rear o2 sensor on my 06 WG. I thought that it was cross threaded, because when I finally got the sensor out, 2 threads were just gone. Luckily the bungs seem to made of harder material than the o2 sensors. I chased the threads with a spark plug tap that I got at the local NAPA store and the new wide band sensors went in just fine ( with lots of anti seize applied to the threads.) There are several posts reporting problems when trying remove o2 sensors. But that should not be such a surprise, look at how many people have a tough time trying to remove the axles because HD applied little or no anti seize to them during assembly.
Good luck with it.
Arcane
Old 08-12-2007, 10:52 PM
jbeauv's Avatar
jbeauv
jbeauv is offline
When I was installing my V&H 2 into 1 big radius pipes , the first thing I did was spray WD-40 on the o2 sensors aft the removal of the stock pipes. I set them off to the side and continued with the install. By the time I got to that part mine came right out with little effort , I guess I was lucky.
Old 08-12-2007, 10:59 PM
mentor70's Avatar
mentor70
mentor70 is offline
Like he says!
This is not uncommon to happen!
I recomend soaking in WD 40 at the base of the sensor and let it soak for a few minutes, then using the correct 02 sensor socket, pull it slightly tighter about an 1/8 of a turn first, then work it back the other way and adding a squirt of WD every turn or two till shes unbound and out of the pipe.
Old 08-13-2007, 07:28 AM
jkelley's Avatar
jkelley
jkelley is offline
Tap size is 21/32 standard 02 thread size.
worked4it
09-23-2018 04:10 AM
ckamin
Exhaust System Topics
05-17-2015 03:06 AM
JockWhisky
02-07-2013 11:14 AM
WideGlideFever
01-29-2013 08:22 PM
Dango
12-23-2009 10:29 AM
Quick Reply: 02 sensors trashed!!!!
