biggest rear tire on 06 FXDBI?
Old 12-28-2009 | 11:14 PM
LX HEMI's Avatar
LX HEMI
Default biggest rear tire on 06 FXDBI?
Anyone know what the biggest tire the rim can handle?
**I know at least a 180mm
***I'm fenderless and strutless, this guy has a 200mm but not sure if it's a stock rim.
http://www.clubchopper.com/forums/sh...ad.php?t=68998
Old 12-29-2009 | 01:30 AM
Tat2u's Avatar
Tat2u
no it wouldn't be on a stock rim or at least i hope not. stock rim is 4.5" so a 180 tire would be the max for that or you can go to a 5.5" or 6" rim with a 200 tire....
Old 12-29-2009 | 01:33 AM
Bluetoys's Avatar
Bluetoys
While that is true, only some 180 tires can be mounted (within manufacturer recommendation) be sure to look at the minimum rim width they suggest in the description before you buy a tire, most shops won't mount it if the rim is too narrow for the tire.
I mounted an Avon Storm on mine.
Old 12-29-2009 | 08:42 AM
JRK5892's Avatar
JRK5892
although this does not answer your question... i am pretty sure when he posted up about the shop that did this build that they used his stock rim, not possitive, but pretty sure
Old 12-29-2009 | 09:58 AM
LX HEMI's Avatar
LX HEMI
Joe, I saw you posted some comments on that dudes thread. I signed up and asked him. We'll see what he says.
Old 12-29-2009 | 10:24 AM
CountryPunk's Avatar
CountryPunk
I Can't be the only one that honestly thinks it looked better with the 160...I don't think it looks Bad, per say, but it's changed the focal point of the bike. I can't look at the bike and think, hm, not a bad looking scoot. I look and think, welp, there's a big fuggin' tire.
Old 12-29-2009 | 10:31 AM
dpriest's Avatar
dpriest
he was a member here a while back. not sure if he"s still active. i also think he used a rim/tire combo he got from a friend. search for his profile on here.
Old 12-29-2009 | 10:48 AM
rounder's Avatar
rounder
that 200 looks wicked with the rear fender he did. I would probably err on the side of caution with this, unless the manufacturer of the tire says it is safe to do, I would not try to put a 200 on a 4.5" width rim.
Old 12-29-2009 | 11:31 AM
LX HEMI's Avatar
LX HEMI
i'm sure you're not the only one, but a 200 does it for me
Old 12-29-2009 | 11:32 AM
SniperCJ's Avatar
SniperCJ
This DEFINATELY doesnt answer your question but...
BlueToys: Your bike looke good with thise bags. What method did you use to relocate the sigs?
Quick Reply: biggest rear tire on 06 FXDBI?
