I'm going with saddlebags now need new advice
http://www.cycleluggage.com/willie_and_max_mhm633.html
$47.95 for the mounting kit
http://www.cycleluggage.com/willie_a...addlebags.html
$151.95 for the bags.
I picked up the little HD logo bolts from my local stealer.
Yes, the bags will work with easy brackets. I'm pretty sure you can bolt easy brackets onto any bags you want.
While I am sure there are better, more affordable bags I have grown to like the Dyna Big Bags that came on my 06 SB.
After a lot of cleaning I have figured out the previous owner had a car port and not a garage so the bike was out in Utah Winter for a couple years. Most likely the reason the upper back snaps wont snap as the leather has shrunk.
You can also see where the previous owner knocked the bike over and messed up the bags an bit but it didn't crush it as I would have thought.
I have seen New or excellent on Ebay for around $300 for the set.
Just my input about what I have.
Karsten
Karsten
Thanks for all the pics. Looks like I can now add W&M bags to my list of possible bags.
Any one know if someone makes a EZ-off bracket that wont push the bags out to much from the fender?
Karsten,, I don't think bags like yours would look good on my Dyna-C but I got to say they fit the look of your bike very nicely, thanks for your pics.
From what I can tell HD don't make a EZ-off bracket for there bags. They do have a detachable leather bag but at close to $900 that's to much for me.
Thanks for all the info so far.
I found mine on Ebay. If you google the part number you might find a couple online retailers that still have them stocked. I found two or three back when I was searching, but I was able to get it cheaper on Ebay.
detachable brackets
I had the Easy Brackets (slim-line) on my Sporty, but they bounced around like hell and stuck out way too far, but they were lockable. And these were closer in than the Ghost Brackets
On the FXDF I went with the BareBacks-rock solid and don't stick out any further than hard mounted. Easy on and off once you get them adjusted right. They don't lock on, but unless you know what you're looking at, you wouldn't know they were detachable. The chrome caps that they sell to cover the studs when the bags are off, dress it up nicely. Be sure to put a little grease on the 0-rings so they go on and off easily
http://www.cyclevisions.com/bag-moun...rebacks-cv144/
BTW I got the bags NIB off E-bay for $200 less than HD wanted (just happened to be the B rather than the C model) And the parts guy at the dealer couldn't tell me what was the difference between the B and C models.
Having been right where you are on the saddlebag decision, I'd seriously consider getting LeatherPros. They are a great deal of coin, but if you are willing to go $500 plus another Franklin for quick-detach .... why not get the best? I can honestly say that I've never wished I had gotten anything but the LeatherPro for my bike. Solid mount up, no rattles, great quality, thick leather, no sags, and easy as hell to install.
PsTaN
PsTaN
