I'm going with saddlebags now need new advice
Saddleman
I have the Saddleman bags with the shock cutout. They are lined with plastic so they hold their shape. They have velcro and quick release latches plus they are lockable too. I mounted them with ghost brackets and relocated the turn signal with a touring light bar.
LeatherPros. Nothing comes close - only detachable bag that doesn't rattle. When they're on, they are as solid as permanently mounted bags. No turn signal relocation. ABS inside so they'll keep their shape. Locks included. Contact Jenni Sapyta at http://www.tri-countyharleydavidson.com/ for the best price out there. You won't be disappointed
Since you mentioned W&M, I installed these Willie and Max bags on my Shovel this Spring. I have to be honest. I was disapointed in the quallity. Not so much they were poorly made, but more that the leather was flimzy and they were packed full of this corregated plastic to maintain shape. Maybe their better Revolution bags don't have these traits, but at least with these American Classis Touring, was was a little dissapointed.
Since you mentioned W&M, I installed these Willie and Max bags on my Shovel this Spring. I have to be honest. I was disapointed in the quallity. Not so much they were poorly made, but more that the leather was flimzy and they were packed full of this corregated plastic to maintain shape. Maybe their better bags don't have these traits, but at least with these American Classis Touring, was was a little dissapointed.
I removed the ugly gold eagle that they came with and filled in the holes with these:
I have no need for bags that are removable as I never take them off. As long as they're big enough to hold my stuff and don't sag, for me, bags are bags I like the look of these particular ones much better once I removed the funny gold eagles.
Thanks to all of you for the pics.
'Dub', sounds like your OK with the quality of the Saddlemen bags. Do your bags open from the side or flip up from the back? I can see in your pic from the back { BTW thanks for that pic} that the bags don't set tight to your bike, is that because of the EZ-off brackets?
I've been looking at Saddleman Drifter Teardrop with shock cut out for under $300 I think they are a bit smaller then yours but a lot better then trying to strap everything to a sissy bar. I've decided to go with some kind of EZ-off brackets because it will make it easier to remove them for cleaning my bike.
Once again all of you are giving me very informative advice. Over the last 3 years the people on the Sportster Forum have been great, looks like the people on this Dyna Forum are the same... Thanks.
Edit... MZBuckeye. I just seen your W&M bags, don't look to bad. What did you use to hard mount them? Do you know if a EZ-off bracket of some kind would work with them?...Thanks.
https://www.hdforums.com/forum/dyna-...addlebags.html
place to get some leather pro's. you had asked earlier if saddlebags can look cool on dyna's. with the ezbrackets pushing out the bags like an inch on each side..... no they don't look cool. They do provide someone the option to detach their bags, however, if your buying new bags and those ezbrackets, wouldn't it make sense to buy a set that will be around the same cost, have built in detachables that have the bag up against the fender, and be the best made bags out there? Then again, maybe the willie & max bags are much less expensive that I though price wise. I do know the ezbrackets are about 150 or so.
