Im upgrading to 103
Im upgrading to 103
Need help choosing parts for my 07 Street Bob 103 upgrade, I live in Dubai & have no access to any HD Tuners or parts. I'll order my parts from the U.S & probably send my engine to Big Boyz to work on it.
I need ideas & recommendations, reliability is very important coz I cant afford sending the engine to the states again if something goes wrong.
Im 215 lbs & I ride solo most of the time, we get 98 octane fuel here (equals 94 in the U.S) so i think compression ratio up to 10.3:1 is fine.
I was thinking of the following parts:
Pistons:
-Wiseco
-CP
-Cycle Rama
Cam:
-Andrews 54
-Andrews 55
-Cycle Rama 575
SE 103 Cylinders
Porting & tuning by Big Boyz.
Thanx in advance for the help guys
Pistons:
-Wiseco
-CP
-Cycle Rama
Cam:
-Andrews 54
-Andrews 55
-Cycle Rama 575
SE 103 Cylinders
My opinion;
http://www.jirehcycles.com/
1) POP-OFF COMPRESSION RELEASE
Price 15.95 Pkg EACH (NEED 2)
Part # 93-772
2) COMETIC HEAD GASKETS
EST spring steel, .030" thickness
Price 26.99 Pkg PAIR
Part # 78-257
3)CAM COVER GASKET
AFM
Price 6.99 Pkg EACH
Part # 78-525
4) Andrews Camshaft 216354 54H 16/42 238 273 .555 .165 Hi-lift New for 2008! Specially designed for 96 & 103 engines
43/15 238 273 .555 .158 with CR up to 10:1 (2200-5600 RPM range).
http://cgi.ebay.com/ebaymotors/ANDRE...item518f1d63d6
5) Harley Davidson Cam Spacers:
25731-060.110 inches
25734-060.120 inches
25736-060.130 inches
6) Harley Dyna Black SE Big Bore Stage I 27535-08
Part Number: 27535-08
http://cgi.ebay.com/ebaymotors/Harle...item5d27542574
7) Port Heads, CC and mill heads to establish EXACTLY 84cc combustion chambers, Drill for 10mm compression releases: http://www.bigboyzheadporting.com/showthread.php?p=17
8) Harley Dyna 06+ primary gasket: Part Number 60547-06
9) TTS Mastertune and download cable: http://www.mastertune.net/
10) Quality 2 into 1 exhaust system of your choice.
That build will get you to 100hp / 100TQ+, and be very reliable, and simple.
Part # 93-772
Part # 78-257
3)CAM COVER GASKET
AFM
Price 6.99 Pkg EACH
Part # 78-525
My opinion;
Part # 93-772
Part # 78-257
3)CAM COVER GASKET
AFM
Price 6.99 Pkg EACH
Part # 78-525
Part # 93-772
Part # 78-257
3)CAM COVER GASKET
AFM
Price 6.99 Pkg EACH
Part # 78-525
My opinion;
Part # 93-772
Part # 78-257
3)CAM COVER GASKET
AFM
Price 6.99 Pkg EACH
Part # 78-525
Part # 93-772
Part # 78-257
3)CAM COVER GASKET
AFM
Price 6.99 Pkg EACH
Part # 78-525
Thanks
speakerfritz
Engine Mechanical Topics
10-02-2011 07:14 AM
