Bike throwing a code?? Help..
Hey guys,
So I think my bike might be throwing codes? But I'm not all to sure..
You know that little light in the speedo that lights up when you hit the run switch? Well, that comes on like normal and goes away after a couple seconds, and thats when I start the bike. But now I'm having that light come on randomly at times while riding, and it will actually come back a few seconds after it turns off when I hit the run switch.
Is it throwing codes or what? I do know that my low beam headlight isn't working. It got messed up somehow when I changed out my drag bars back to apes. But my high beams work, and that's what I've been running with everytime I have my bike on.
The bike does seem to run fine without any issues. Sometimes starting the bike up is a bit rough, but it starts.
Anyway, any suggestions would be appreciated!
Lets try to narrow it down, when you say the little light that comes on with the run switch, I'm gonna guess you are talking about the little amber colored light that resembles and engine, yes/no? I believe there is also a blue light that comes on when you have your hi beams on, and since you have your hi beams on all the time you should be getting that on all the time. Once we determine that, then, you've got an 06 streetbob, typically when the engine light comes on after the run switch comes on, it's a power up mode feature test, then goes out after I believe about 5 seconds, if it comes back on for approx 6-8 seconds, then goes out you have a stored fault. If it stays on after 5-8 seconds you have a current fault.
So we can start with that then determine if you need to pull any codes from your ecm if you have any.
Adrian,
Sounds like you don't have the 'how-to' for retrieving the codes so I'll post it again.
These will also work on the 07 & 08 bikes.
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble
codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing
speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background
lighting sould illuminate, speedometer needle should sweep its full range and
indicator lamps (battery, security, low fuel, check engine and cruise) should
illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt"
with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is
flashing is the one you are going to check. To move from one letter (module) to the
next, you push the odometer reset button one time. (from P to S to SP to t and back
to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module
[Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset
button in for 5 seconds and release. If there are any DTC’s the code will be displayed
or the word “none” will appear if there are no DTC’s. Push the odometer reset button
again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part
number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by
pushing in and holding the odometer reset button ( longer than 5 seconds) until
'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch.
Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to
9. If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the
tachometer identifer is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this
proceedure.
DTC FAULT CONDITION MODULE
"BUS Er" Serial data bus shorted/low/open/high
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1122 Right turn output fault
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1141 Ignition switch open/low
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0131 Front 02 sensor low (lean)
P0132 Engine running rich
P0134 Front 02 sensor open/not responding
P0151 Rear 02 sensor low (lean)
P0152 Rear 02 sensor high (rich)
P0154 Rear 02 sensor open/not responding
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM Error EFI
P0604 RAM Failure Carb
P0605 Program Memory Error Carb
P0605 ECM Flash Error EFI
P0607 Converter Error Carb
P0661 Intake solenoid low/open
P0662 Intake solenoid high/shorted
P1001 System Relay Coil Open/Low EFI
P1002 System relay Coil High/Shorted EFI
P1003 System relay Contacts Open EFI
P1004 System Relay Contacts Closed EFI
P1009 Incorrect Password Carb
P1009 Incorrect Password EFI
P1010 Missing Password Carb
P1010 Missing Password EFI
P1351 Front Ignition Open/Low Carb
P1351 Front Ignition Open/Low EFI
P1352 Front Ignition Coil High/Shorted Carb
P1352 Front Ignition Coil High/Shorted EFI
P1353 Front Cylinder No Combustion EFI
P1354 Rear Ignition Coil Open/Low Carb
P1354 Rear Ignition Coil Open/Low EFI
P1355 Rear Ignition Coil High/Shorted Carb
P1355 Rear Ignition Coil High/Shorted EFI
P1356 Rear Cylinder No Combustion EFI
P1357 Intermittent Secondary Front EFI
P1358 Intermittent Secondary Rear EFI
U1016 Loss of ICM/ECM Serial Data Instruments
U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Powertrain
Security Status TSM/TSSM
U1064 Loss of TSM/TSSM Serial Data Carb
U1064 Loss of TSM/TSSM Serial Data EFI
U1064 Loss of TSM/TSSM Serial Data Instruments
U1097 Loss of Speedometer Serial data Carb
U1097 Loss of Speedometer Serial data EFI
U1097 Loss of Speedometer Serial data TSM/TSSM
U1255 Missing Message at Speedometer EFI
U1255 Serial Data Error/Missing Message EFI
U1255 Serial Data Error/Missing Message Instruments
U1255 Serial Data Error/Missing Message TSM/TSSM
U1300 Serial Data Low Carb
U1300 Serial Data Low EFI
U1300 Serial Data Low Instruments
U1300 Serial Data Low TSM/TSSM
U1301 Serial Data Open/High Carb
U1301 Serial Data Open/High EFI
U1301 Serial Data Open/High Instruments
U1301 Serial Data Open/High TSM/TSSM
2006 models with 02 sensors (Dynas)
P0131 Front 02 sensor lean for any length of time
P0151 Rear 02 sensor lean for any length of time
Above codes can also be set if 02 sensor fails.
AFR – Air Fuel Ratio
ATS – Air Temperature Sensor
BAS – Bank Angle Sensor
CCM – Cruise Control Module
CKP – Crank Position Sensor. The CKP generates an “AC signal” which is sent to the
ECM where it is used to reference engine position (TDC) and speed. Home position
established by taking readings off the 22 teeth on the alternator rotor.
DTC – Diagnostic Trouble Codes
ECM – Electronic Control Module. (The Computer) Computes the spark advance for
proper ignition timing and fuel control based on sensor inputs (from CKP, MAP & TP
sensors) and controls the low-voltage circuits for the ignition coils and injectors. The
dwell time for the ignition coil is also calculated in the microprocessor and is
dependent upon battery voltage. The programmed dwell feature gives adequate
spark at all speeds.
ECT – Engine Coolant Temperature. Sensor also controls the cooling fan relay that
provides 12 Vdc to the fans.
EFI – Electronic Fuel Injection
EFP – Electronic Fuel Pump
ET – Engine Temperature sensor
FI – Fuel Injectors
FPR – Fuel Pressure regulator
IAC – Idle Air Control actuator
IAT – Intake Air Temperature sensor
ISS – Ion Sensing System…detonation detection
MAP – manifold Absolute Pressure sensor. The MAP sensor monitors the intake
manifold pressure (vacuum) and sends the information to the ECM. The EMC then
adjusts the spark and fuel-timing advance curves for optimum performance.
TP – Throttle Position Sensor
VE – Volume Efficiency
VSS – Vehicle Speed Sensor. Used as an input for idle speed control
codes).
to P, etc.)
[Carbureted])
SP = speedometer
T = tachometer
proceedure.
P0501 VSS Low Carb
P0501 VSS Low EFI
FI – Fuel Injectors
Well she's low on oil! Makes sense because I've been hearing a hell of a lot of ticking, which would usually indicate low oil. I checked the dip stick just now, and it was less then a quarter of the way up. I gotta do an oil change this weekend, so hopefully that'll solve the problem.
I'll be saving this thread for sure though, cause that diagnostics listing is crazy helpful. Damn I love these forums.
Thanks fella's! I'll keep you guys updated.
