Bike throwing a code?? Help..
Well she's low on oil! Makes sense because I've been hearing a hell of a lot of ticking, which would usually indicate low oil. I checked the dip stick just now, and it was less then a quarter of the way up. I gotta do an oil change this weekend, so hopefully that'll solve the problem.
I'll be saving this thread for sure though, cause that diagnostics listing is crazy helpful. Damn I love these forums.
Thanks fella's! I'll keep you guys updated.
I saved a PDF file when I saw it on here and have a copy on every computer I own j.i.c. I know it's available on here somewhere, but it's just a lot easier to copy and paste than it is to find it and paste a link.
BLAH! Still throwing codes...
CRAP!
Ok, so its very strage.
On hard acceleration, the light inside the speedo, (the light that turns on when you hit the run switch) is still turning on! Its really wierd..
When I'm accelerating a bit aggressively, the light comes on. I think it actually comes on when I hit a certain RPM range.
Any idea's fellas? I've never seen anything like this..
I guess I'll try and run that diagnostic list, but I get the feeling I'm gunna F this up.
Adrian, just having my coffee now and getting ready to go to work so can't really help you much right now but I know ratbob posted that long ole post on your thread the other day, just read that sucker and you'll be able to stumble through it man. You are not gonna f anything up just to pull a code, it's super easy, once you pull the code you can even erase any stored codes but make sure you write any codes down first, then post em on here, so we can try to diagnose the area throwing em.
Good luck man,
Good luck man,
