Another 2 into 1 question, Rinehart or Fat Cat
Old 12-19-2009, 11:47 AM
Kytann's Avatar
Kytann
Kytann is offline
Originally Posted by rounder
true, but, their torque curves and how they come on through the RPM range will be quite different. we ride 99% of the time through the rpm range and not at peak HP and torque. Heck, my big radius 2-2(BCT baffles) had about the same peak HP and torque on the dyno, yet the curve and the way the D&D feels on the road over the big radius is unbelievably different.
Exactly why I'm asking the question.
Cost and looks seem to be about equal. I doubt sound would really vary that much between them, though I have read the FatCats are ever so slightly quieter.
CountryPunk's Avatar
CountryPunk
CountryPunk is offline
NICE!! haha
Old 12-19-2009, 12:27 PM
bigdaddy33's Avatar
bigdaddy33
bigdaddy33 is offline
Very well said. Totally agree.
Old 12-19-2009, 12:39 PM
rounder's Avatar
rounder
rounder is offline
so it is simple, you want a nice torue curve get a D&D, you want less power in your usable rpm range get the rinehart's.
Old 12-19-2009, 05:02 PM
'09fxdb's Avatar
'09fxdb
'09fxdb is offline
1. That's part of the problem, Winter here in Minnesota, no riding.
It's pretty warm out today, all the way up at 22 degrees...
2. Never said anything about Handling. Just as an example of where I'm used to revving a motor
3. Exhaust gas velocity. Yes. Exhaust theory: You have to keep the exhaust gas velocity high to make power. That's why you loose torque if you go with an exhaust that's too large. The velocity drops and each pulses exhaust gases don't effectively get out of the way of the next one. If the velocity is high you get a scavenging effect.
If you go too small the exhaust velocity stays high, but it becomes a restriction.
So Ideally you want it just large enough to flow at max throttle, so it's not a restriction there, and just small enough to keep velocity high at small throttle openings.
Couple that with large abrupt direction changes tend to slow the exhaust down.
It's part of why Header Wrap works to make more power. Without header wrap you're radiating heat out of the headers. Well that lost heat causes the exhaust gas to shrink. This causes it's velocity to drop, and so on.
Conversely when you wrap the headers the heat stays in the exhaust gases and velocity stays high.
Yes I am an engineer, why do you ask?
So don't you think some of your engineering buddies thought about this before you???...There is some engineering that goes into a product such as this...kinda keeps us all from having to be engineers....+..your exhaust gas thingy...10th. grade physics class..
Old 12-19-2009, 05:08 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
No in practical application from reading people experiences it seems like the D&D is more of a low-end pipe. Relative, as it doesn't exactly suffer on the top end.
And that the Rinehart is more of a high end pipe. RPM wise that is.
Sound like I got my facts right so far?
Nope. Sounds like you have been misinformed.
The rinehart is more geared towards milder builds while the D & D kicks *** on a wide range of builds. Besides, Rinehart is a different company (as of this year) and their warranty is almost non-existant. I'd stay away from them. However, their Bub 7 2 into 1 is supposed to be a pretty good performing pipe. But there is a risk that they ain't even gonna be the same now that they ain't even gonna be made at the same place anymore. Buy them if you are okay with risk taking.
D & D's are a proven performer, with a fit and finish that is hard to beat.
Old 12-19-2009, 05:14 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
Originally Posted by CountryPunk
This is such a tired subject. All 2-1's are about the same. Pick whichever you think looks and sounds the best. They are ALL going to be within a horsepower or two.
Not between these two comparisons. The rinehart 2 into 1 is a pretty weak pipe (for a 2 into 1). It's great on the milder builds.
The bub 7 is not the same pipe and will perform within range of the Fatcat.
Old 12-20-2009, 09:35 AM
rounder's Avatar
rounder
rounder is offline
interesting about the rinehart. I had actually remember a few threads a year+ ago about a few people loosing power with the rineharts. I haven't found them in my search though.
Old 12-20-2009, 10:12 AM
CountryPunk
Isn't the RB Racing pipe better than both of those?
Old 12-20-2009, 12:13 PM
rounder's Avatar
rounder
rounder is offline
could be .... they make a great pipe, might get one myself, have never seen a comparison from fatcat to RB pipe though.
Quick Reply: Another 2 into 1 question, Rinehart or Fat Cat
