06 DYNA and TRUE-TRACK
RE: 06 DYNA and TRUE-TRACK
ORIGINAL: ranger140892
The Sputhe stabilizers look like the way to go for my wide glide. Anyone know what they cost? Sputhe's websited does not list the price.
I am very happy with the quality of this product and how it lines up with all the bolt holes.
With only the front installed the vibration is already reduced.
ORIGINAL: ROADTRAIN
I an fitting the TRUE-TRACK to our Dyna now. The front is on and the back is not so easy but should have it finished in a day or two if time allows.
Is that a Sputhe or Tru Trac? How much did it cost. Are you going to have to re-align the engine?
mhbetzer, ride Dyna's and FL's long enough and you'll have squirrely ride experience. Rubber motor mounts are usually the cause.
ROADTRAIN:
I thought the true track was a rear stabilizer only?
Yours is front and rear????
it looks like the sputhe
I really want to get rid of the" rear wheel steer " do you have to re-align everything????
do the instructions tell you how to do the alignment and do you need special tools for the alignment.
I called sputhe...price is $338.00
I am just not sure I have the skills for the alignment part....I wish it was just bolt-on.
Patch,
I too thought it was rear only, same as for my roadking but is supplied with front a mount for Dynas.
The front is no problem as far as alignment because you bolt it up as existing. The rear can't move that much if any but you will need to check it's position. I have a lazer which I attach to each side of the wheel and measure against the front wheel, you could also use a long straight edge.
As I have not completed the rear I don't know how much adjusting is required but if the alighnment were out you would feel it when riding.
ORIGINAL: Patch
ROADTRAIN:
ROADTRAIN:
I'm going to get this kit but there's one thing that scares me. Since it reduces vibration, it's obviously holding the motor more rigidly. Wonder what the chances are of breaking the mount extensions on the front of the engine cases?? Most after market motors, with extra horses, have more beefy mount extensions than Harley's to compensate for increase torque on the mounts.
What about crank bearing problems??
Can't believe I'm saying this but I almost wish HD just used counter balanced motors on all models and quit using rubber mounts.
Anyone have any thoughts here?
ranger,
The primery function for this is to eliminate any sideways movement of the rear wheel in relation to the front wheel,the objective is not to reduce vibration in the vertical plane but I think the reduction is felt because of excessive sideways movement caused by engine momentum is not being allowed to happen. The engine is still free to vibrate but not sideways.
What we now have is a set up that allows total adjustment of the aligment of the rear in relation to the front the same as a wheel alignment with your car.
