Handling question?
Because you almost have to exceed the posted speed limit to find this flaw and going fast around corners is not what a cruiser is designed for or what most cruiser riders care about so,..they can get away with it. And in the MOCOs defense the few bikes they built with quality suspensions the 1200S and the FXDX didn't sell all that great. IMO for what these bikes cost they should have ALLOT better suspension components than they do and they should have solved the rubber mounted swing arm issue by now.
Lowering the suspension, especially the rear only accentuates this issue.If you've only lowered the rear and not the front you can get some stability back by sliding the fork tubes up in the triples some.Also firmer spring rates front and rear will help if not completely eliminate this issue.
With your Burly Slammer kit installed, you even have less room for error on those high speed sweeping turns. You still have the crappy stock Harley rubber mounted swingarm bushings, coupled with 1.5 - 2 inches less suspension travel because of your stubby Burly shocks. I would think that the lateral instability/wobble would be much more noticeable on your bike than a stock Harley.
I love the look of your bike, but why not use something like True Track, if it will shore up lateral stability, and greatly improve the handling characteristics of your scoot? Just my 2 cents.
Most people who have ever rode a FXDX or 1200 sport with better tires than stock would say it lacked nothing in handling ability. Again, they didn't sell well which i take to mean most Harley riders are more interested in looks not performance. If you ride slow in a straight line they all handle just fine.
![Thumbs up](https://www.hdforums.com/forum/images/icons/icon14.gif)
Lateral stability on Dynas suck, especially in the situation you mention above.
I would give True Track a try. You're basically adding a stabilizer link to the front and the rear motor mounts. I'm told that it really helps handling by isolating the lateral movement of the engine/tranny/swingarm. This keeps the rear wheel in line with the front during those high sweepers at 80 mph +, and eliminates the wobble. Your mileage may vary.
I have an FXDXT with a TT. These things not only improve ride and handling as others have described, but even in a straight line. I also have one on my Glide and they are great!
I am mostly adding this for other readers in case they end up wanting to lower their bike and not have a tradeoff in stability.
Thanks for all the feedback. How difficult is it to install? The ride now is not that bad, like I said I can live with it, but I'm sure if I could ride with it installed, I would be glad I did it. I'm borderline on either doing it or just letting it be. Dilema's? I found the installation instructions on the TT website, was it a pain the *** to install? Thanks
Try to ride a Harley like a crotch rocket & you discover they Harley's shortcomings in the handling department. Ride the Harley like a Harley and it's fine. If you want to ride like you're on a crotch rocket, add one to your garage. Then ride the bike that fits your mood or ride that day.
