Dyna shifter shaft replacement? Easy or not?
Old 12-09-2009, 10:02 AM
07bobber's Avatar
07bobber
07bobber is offline
Default Dyna shifter shaft replacement? Easy or not?
Gonna help a friend replace the shifter shaft in his 06' streetbob this weekend. Figure id ask here if its a no brainer from the experienced. And i do have a manual just in case i get lost lol. Also is there anything else i should check while im inside the primary since it is an 06?
Old 12-09-2009, 10:34 AM
thedonthere's Avatar
thedonthere
thedonthere is offline
Tell him to replace the IPB with the heavy duty Baker one since you will already have it open.
Old 12-09-2009, 10:41 AM
07bobber's Avatar
07bobber
07bobber is offline
Ill bring it up but i doubt he has the cash for that right now. The least i could do is check it out tho...he called me last night and asked me to help him by doing this for him (he's a newbie) cuz he knows i do my own work and an indy quoted him 250 in labor just to replace his cuz its stripped.
Old 12-09-2009, 11:05 AM
thedonthere
You can get one for $12.00-$16.00 from a bearing house. There are plenty of those in your area. I lived in Escondido for 20 years.
I can't find the package I had for the # but someone on here should have it.
Old 12-09-2009, 11:30 AM
07bobber's Avatar
07bobber
07bobber is offline
Oh sweet i was thinking the cost was a lot more...he should be able to afford that lol
Old 12-09-2009, 01:13 PM
REVL33's Avatar
REVL33
REVL33 is offline
from what i have been reading you cant afford not to , unless you have to go with a new case that is a whole nother ball game .
Old 12-09-2009, 09:36 PM
ackman1968's Avatar
ackman1968
ackman1968 is offline
Which shaft is he replacing? If it's the one that goes through the primary I have one if he needs it. It's the last piece of the mids I have left, cost of shipping and it's his. The baker bearing number is 6205Z if I remember correctly. I know it was posted in one of the IPB threads, might have been the one Patrick started with the poll.
Snekbitt
02-01-2019 10:24 AM
hardheaded
01-28-2019 03:21 PM
Gibbs03EG
08-13-2014 02:31 PM
luisan
11-14-2012 07:04 AM
tbone52
09-27-2009 09:14 AM
Quick Reply: Dyna shifter shaft replacement? Easy or not?
