Thunderstar dual rotor front wheel on FXD
Ok. So I just bought on ebay a Thunderstar 19" front wheel that currently has 2 rotors mounted up to it. I am just trying to verify that this should fit on my wifes superglide. I looked in the accessories book and it gives one part number for all 19" front ends up to 05. Am I correct in assuming that I just remove one rotor and run it with only the left rotor used? I could only find any information on 1 black thunderstar 19" front wheel, so I just assumed this was the right wheel.
It will fit, and if you pull off the right side disc, you will need to get a hub cap for that side. Normally the wheel comes with one, but since this is coming from Ebay it probably won't have it.
For what it's worth, here's a link to the Harley instruction sheet for that wheel.
http://www.harley-davidson.com/en_US...ts/-J04065.pdf
Here's the part number for the hub cap:
43986-00 and refer to page two under the heading for Single Brake Disc Models.
Thanks for the information. I will have to check into that hubcap plate. Now I am just hoping that the 2 rotors that are on it are not the same. Someone put a brand new set of rotors on it and I am hoping to get lucky and they screwed up and used a front and a rear. If not, I'll just have to sell 1 rotor and buy a matching rear.
NO don't swap bearings, get new ones! they are cheap. You can probably reuse the internal spacer from the old wheel though.
