spacing the rear pulley
I have a '93 FXDWG and a friend mechanic told me that if I put a couple of spacers in the rear pulley I can run the stock OEM belt with a 150 tire in there. Can this be done????. How much would this affect the ride?
Another friend mechanic says that thiss will make the bike pull to the left and to just get a thinner belt and a thinner pulley... the thing is that to be honest, I don't want to spend that $$$ (or on spacing the primary) for this since I have no problem riding the stock 130 tire, but I would like the looks of the 150.
I dont want to make my bike less reliable with a smaller belt that might brake easier...
This can be done, but you can't go too far out. You can buy the spacers from JP Cycles and other aftermarket parts shops.
If I remember correctly, you need a 1/4" spacer for this mod. That will move the pulley away from your hub .250" which tranlates to about 6mm. That plus cutting the existing gap between belt and tire by 4mm will allow the 150. The belt will be closer to your tire, but as long as your wheel is straight it won't rub.
I am in the process of doing this very mod. The wheel is having a 150/80 Avon Venom fitted as I write. I have previously run a 140/90. I still have a wide belt. With the 140 on the bike I had just 3/16" clearance between the tyre and belt and removed the rubber curtain on the belt guard to get it in.
In the case of Avon Venoms their 140/90 is actually 143mm wide while their 150/80 is exactly 150mm wide. So with a 150 that 3/16" clearance I mentioned will be reduced to just .040" or 1/20". A bit too close! I am fitting two 1mm thick spacers, which will increase that clearance to 1/8".
Hope that helps! I am doing some other mods, so it may be a few weeks before I rebuild my bike and check everything is OK, or find any problems.
Bad choice of words, you're not cutting anything. What I meant was that you have an existing gap between your belt and tire. That gap is usually sufficient to make up a few more millimeters and allow for you to use the smallest spacer possible.
6.35mm spacer + existing gap (3 to 7.9mm or 1/8 to 5/16" (you should measure what you have now to calculate needed spacer size))= total mm you can increase tire size before hitting belt.
Essentially with my example, you'd be using 3.65mm of any existing gap between your belt and tire to increase tire size by 10mm total.
PaulG75 (03-01-2021)
Seems you need to be reminded that the USA went metric in 1975. Unfortunately when the law was signed off someone forgot to say when. Since then the rest of the World has done what your Government said they were going to do! You have some catching up to do....
I honestly don't get the wide tire kits... and this has to do with the mod that I want to do.
What do I need to make room for a bigger tire (besides the tire and wheel)? I don't get it... I think I can get those parts individually cheaper... so can you list what will the parts be on a kit?
I get that you need basicly is to space out the primary, have a longer crankshaft, a wider swingarm and a wider fender with the struts... and I think that all of that can be found for less than the normal 2K that a kit normally goes for!
