New rear LED turn signals installed
Voony - I do not know if these can be used as a multi function type light (Brake,Running,Turn signal). There is no mention of that in the instructions. They are a two wire signal as are the stockers, so it was a straight connection. I can keep you posted though because I was planning on installing that mod pretty soon.
Sanlyn - I did NOT install a load equalizer. The instructions said that I "may" have to if the lights flashed rapidly or did not work at all. I installed the left side first and tested it. The very first time I tested it, it Did flash rapidly. But then I switched to the opposite side (Right side) and it was normal, Then when going back to the one I had just installed (Left side), it functioned "normal" and has ever since. I know it sounds strange, but that's what mine did.
