Dyna Footboards.......Review and Pix's
#61
I didn't have to, I already had forward controls so just mounted the floorboards and away I went. 20-30 minutes tops...
#62
Hello TailGunny,
I believe that You can get shifter shaft cover (HD #34640-93) and a primary shifter lever retainer bracket (HD #34639-01). I ordered mine from boardtracker Harley Davidson in Wisconsin for 21 dollars for both i believe.
I ordered the Harley footboard kit (HD #50500247) and the shift cover and bracket all together.
Good luck to you.
Chris
#63
Some links to relevant info:
Instruction Sheet -J01921
Instruction Sheet -J02241
Instruction Sheet J05615
#64
#65
clutch
Hi read in a old thread that you converted cable to hydraulic clutch.
Can you let me know wher to look for these parts.
I have a Softtail night train 2006 FXSTBI, and wnt to convert to hydraulic clutch
with black transmission cover and black clutch master cylinder
many thanks
Magnus from sweden
many thanks
Magnus from sweden
#66
question to puttnutt24
many thanks
Magnus from sweden
many thanks
Magnus from sweden
texasrpbrock
11-27-2016 02:55 PM
