Where does the green wire go?
Old 11-28-2009, 10:55 AM
sniper77's Avatar
sniper77
sniper77 is offline
Default Where does the green wire go?
Trying to wire up a tack and not getting a signal yet....any ideas?
Attached Thumbnails Where does the green wire go?-pict0019.jpg   Where does the green wire go?-pict0008.jpg
Old 11-28-2009, 11:02 AM
SuperFastGlide's Avatar
SuperFastGlide
SuperFastGlide is offline
your instructions say to the negative side of the coil... i thought the tack feed on injected bikes was off the ECM though..
Old 11-28-2009, 11:05 AM
JT-FXDL's Avatar
JT-FXDL
JT-FXDL is offline
I'm not sure if this will help, but this is a link to a guy installing a tach in his Shadow.
http://www.eurekaboy.com/shadow/tach.htm
Old 11-28-2009, 12:29 PM
TexasFXD's Avatar
TexasFXD
TexasFXD is offline
6th Gear
Looks like you have the wrong kind of tach. You need a digital tach that connects to the DATABUS wire.
Old 11-28-2009, 02:13 PM
fixxr's Avatar
fixxr
fixxr is offline
You can run the green wire to the neg side of the coil but you should use use a shielded wire so the signal don't mess up your ECM
Old 11-28-2009, 02:18 PM
jarhead45's Avatar
jarhead45
jarhead45 is offline
look at pin 2 .. the lgrn/v wire ... that is your tach signal.
Old 11-28-2009, 02:26 PM
sniper77's Avatar
sniper77
sniper77 is offline
That is not what I was hoping to hear.
I need a bit more information on this suggestion...a shielded wire?
I tried that and the needle bounces when cranking the engine but when it starts the needle returns to zero and just sits there.
Old 11-28-2009, 03:41 PM
fixxr's Avatar
fixxr
fixxr is offline
The OEM tach wire is set up to run off a Data-Buss(one wire is used for more than one thing)the tach you have needs to run off the coil.the shielding stops the the signal from going any where else.
Old 11-28-2009, 03:50 PM
sniper77's Avatar
sniper77
sniper77 is offline
Okay, now I understand why I need shielding but I still don't know is what it is and how I go about getting it.
Thanks BTW.
Old 11-28-2009, 04:23 PM
ColdCase's Avatar
ColdCase
ColdCase is offline
If the 2006 is a delphi ECU, it should provide a tach signal at pin 3. You will have to add a pin to the connector. Most tachs, regardless of make, will work off of that signal.
http://www.hdtalking.com/electrical_...bus_bikes.html
Here is someone that did it on a 2006:
http://www.shareaproject.com/pages/i...i,2354,00.html
Quick Reply: Where does the green wire go?
