Where does the green wire go?
Old 11-28-2009, 04:50 PM
2003Springer's Avatar
2003Springer
2003Springer is offline
Originally Posted by SuperFastGlide
your instructions say to the negative side of the coil... i thought the tack feed on injected bikes was off the ECM though..
Your right.. don't think itwill work without screwing something up. It may but I wouldn't. JMHO
Old 11-28-2009, 06:12 PM
mud's Avatar
mud
mud is offline
muderator
Received 9,109 Likes on 2,119 Posts
Originally Posted by sniper77
Trying to wire up a tack and not getting a signal yet....any ideas?
I would call the manufacturer of the tachometer,
and ask them for hookup details for HD..........
Old 11-29-2009, 10:11 AM
sniper77's Avatar
sniper77
sniper77 is offline
Originally Posted by ColdCase
If the 2006 is a delphi ECU, it should provide a tach signal at pin 3. You will have to add a pin to the connector. Most tachs, regardless of make, will work off of that signal.
http://www.hdtalking.com/electrical_...bus_bikes.html
Here is someone that did it on a 2006:
http://www.shareaproject.com/pages/i...i,2354,00.html
Awesome, thanks!
Old 12-12-2009, 08:03 AM
sniper77's Avatar
sniper77
sniper77 is offline
This worked flawlessly. A huge thanks going out to you for the link ColdCase!
Old 12-12-2009, 11:52 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
this is the one that i followed on mine
oops man, just read this and realized you are all good... you are going to love the tach!!!
leafman60
02-01-2021 06:27 PM
bolillo57
06-17-2013 04:05 AM
Thierry
02-24-2011 02:11 PM
90ssharley
Electrical/Lighting/Alarm
03-17-2009 09:55 AM
90ssharley
03-15-2009 12:03 PM
Quick Reply: Where does the green wire go?
