Oil Change Guidance?
I am doing some work on the bike so I figured while I was doing this I would also preform an oil change. I do not have a manual for the bike as it was a repo purchase. So I want to make sure i put in the correct fluids and amount in the Engine and Primary/tranny.
First off, I am an Amsoil guy so with that out of the way and knowledge on changing the engine and primary/tranny oil on a Sportster. Here are my questions:
1. Does anyone know of a good online guide for doing this on a Dyna? (Engine & primary/tranny)
2. What wight oil do i use? Amsoil MCV 20W-50?
3. Is the primary/tranny still one peice?
4. Can I also use Amoil (Amsoil MCV 20W-50?)in the primary/tranny like I could on the Sportster?
5. How many qts for the engine?
6. How many qts for the primary/tranny?
I think that covers everything.
Thanks,
Joe
Thanks,
Joe
I hadn't seen an oil question in quite some time. These posts usually attract like 4-5-6 pages of answers,so imagine how many opinions you will get.
Amsoil 2/50 is great that is what I use in the tranny and engine.So far I've stuck with HD formula for the primary which is separate from the tranny,and they run each 1 quart. the engine takes 2.5 quarts. Lots of guys use amsoil in all three holes. others swear on heavier oil for the tranny = gear oil 80/90 and even heavier. and still others use ATF for their primary/clutch compartment. Good luck and welcome to the forums.
Suggestion= buy a manual you will enjoy it! best money spent to save money with!!!
Received 4,807 Likes
FBFletch
Oil Archive (no new posts)
06-08-2006 01:20 AM
