New PIAA Headlight *pics*
On the recommendation of our local Indie, I bought a PIAA headlight bulb for about $50. Specifically it was the model H-383SE, described as having a bluish purple low beam and a Xtreme white High beam. I was told this sucker would really light things up. Eh, not so much.
I found a dark road tonight and took some before and after pics for both lo and hi beam. They are below, the first two are low beam: stock, then PIAA, second two are hi beam: stock then PIAA:
Aside from the shaking from the motor making for bad pictures, you can see that there was not much difference if any. The color change was the most noticeable part, but even that was minimal. Not worth the $$ IMO, but I will leave it.
Steve
Steve
on the low beams, I can count more lines in the road. Maybe an extra 10-20 feet. It is not much of a difference however at speeds, seeing 20 feet further could be very beneficial. IMHO, if you want real good light, seek out Howard at motorcycle metal and purchase one of his HID systems. Not all that expensive for the light it will produce.
I used to run the same bulb... only prob is they burned out so fast... I put them in both my wifes and mine, they did not make it the summer (when i first bought the bike) left her stranded in the middle of no where... it was a mess... Silverstars are what i rock now... going on 3 years same bulb
