true track for dyna's
It's probably one of the most discussed topics in this forum. A search will probably turn up 1000 or more hits.
Anyhow, most everyone who installed one seem to swear by it.
Do you have a dyna? I see you have almost 2000 posts, where have you been?
BTW, great looking wheel in your sig pic.
Always ready to share my opinion, I copied a recent ride report I wrote in this forum for your convenience...
I know many have done a ride report on True-Track, but here I go with mine anyway. I just got back from an 80 mile round-trip along the Yakima river canyon (read: lots of twisties). I pushed it as hard as my skills could take it.
My first impression was that the bike felt tight. Apparently my brain interpreted 'tight' as 'harder to turn' - which was not the case. How this played out was when I was coming into a tight corner I wanted to (and often did) corner too hard, then had to straighten up and find the right line and go from there.
The next big impression was that I didn't have to actively steer as much. The wording in my head at the time was 'not as many steering inputs were required.' I felt like I could take my hands off the handle bars most of the time. One of the ways this played out was when riding one-handed. Prior to the True-Track, I'd have to keep a pretty firm grip in the right handlebar and keep a lot of forward push on it to make it track straight. Now just a couple of fingers to keep the throttle open.
When I was able to initiate the right track on a hard corner, it was like the bike was on rails. I know that is easy to say, but for the first time I felt like steering wasn't the issue it was whether the bike was going to break sideways or not with the centrifugal force.
And it didn't seem to matter about road surface conditions. I felt all the patches, bumps, holes, and whatever as always, but they just didn't translate into steering/tracking problems.
Awesome. Well worth the $305.
Steve
Steve
Thanks Vic! It's just that initial fraction of a second and I was trying to find out if that could be interpreted as "rear-stearing". Maybe i can still twist ,but more gradually,or I may have to start buying metz' or avons to meet my needs. We shall see!
The one stabilizer on Dynas is between the heads, under the gas tank. The True-Track kit provides the brackets and links to fit stabilizers in front of the engine and at the rear of the gearbox. So with a TT kit installed, your Dyna has the same set-up as a Buell!
As others have already stated, once fitted, the bike steers and handles far better, even in a straight line. I also have one on my 1990 Glide, so all three of my bikes have three stabilizers! It is the only way to go. I would also add I bought both kits before TT started sponsoring HDF. If you talk to them nicely they might give you a discount.
Just to add that Sputhe also makes a good chassis stabilizer. Sputhe will sell you each half separately. If you only plan to install the front, which is an easy mod and gives you about 95% effectiveness, you can save 50%. The rear is a PITA to install on a Dyna.
Both chassis stabilizers work the same and cost about the same. Sputhe is a little more compact which makes it easier to also fit an HD oil cooler. TT is a forum sponsor.
