1000 mile service?
1000 mile service?
Can anyone give me an idea of what the dealer does on a 1000 mile service? The dealer I bought my bike from said I should bring it to them for the service. If they are only going to change fluids id rather do it myself and put the oil that I want in there. If there is much more to the job I am willing to let them do it and change my oil after I get it back. I guess I could always ask if they can do the service without the oil change and see what they say. Just trying to get an idea since it wont be long before im due for the service.
Thanks
Dave
Thanks
Dave
RE: 1000 mile service?
not much more really. they check bolts,etc to be tight. adjust clutch. a few other small things. i for one can not see paying them the cash.
lots of great people here if you need advice on things !!!
get the service manual for sure tho. well spent $$ .. i ordered mine from surdyke harley,about 44.00 on line. good price,best price i could find anyways .
ORIGINAL: Psycho Dave
Thanks
Dave
Thanks
Dave
Little more than fluids.
Change Engine Oil
Replace Oil Filter
Change Primary Lubricant & Clean Drain Plug
Check and Adjust Chains/Belts
Inspect and Service Air Cleaner
Check Battery fluid & Clean Terminals
Check Rear Brake Pedal Adjustment
Inspect Break Pads and Discs for Wear
Check Brake Fluid Levels and Condition
Inspect Oil Lines and Brake System for Leaks
Lubricate Clutch, Throttle, and Idle Cables & Levers
Check and Adjust Clutch, Throttle, and Idle Cables
Check Tightness of All Fastners; less Head Bolts
Check Tire Pressure & Tread Condition
Check Engine Low and Fast Idle Speeds
Inspect Fuel Lines, & Fittings for Leaks
Check wheel Spoke Tightness
Adjust Steering Head Bearings
Check Operation of all Electrical Equipment & Switches
Lubricate & Adjust Front Fork Bearings
Change Transmission Lubricant & Clean Drain Plug
Check Condition of rear Shocks
Grease Wheel Bearings
Change Front Fork Oil
Check Stabilizer Links & Engine Mounts
check air suspension Pressures & Lines for Leaks
And the one I like the most. Test Ride
