Bob surging
Bob surging
I have noticed the last couple of times out that whae my bike gets warm that it starts to surge. When i am coming to a stop and gearing down then pulling in the clutch is when i will notice it, the rpms will go up and the bike will kinda flutter a bit. Not sure if i described this well enough but its basically not running to great. 06 street bob se slip ons se/ac stage 1 download
RE: Bob surging
There are 2 stage one downloads for the 8 degree injectors. The first download was not (if you can believe this) tuned for slip ons, just the Air cleaner. The second download is a bit better but ultimately all of these downloads are lean and cater to the EPA rather then a good running bike.
Here is pic of the A/F table which is identical on all closed loop bikes. No tuner in their right mind would setup a bike like this. Fixing this table is a big part of fixing some of the issues with these bikes and why there is no contest which tuning aid on closed loop systems is the best which, of course, is the SERT.
RE: Bob surging
ORIGINAL: clayman
FL_799. I have a sert on order it should hopefully be here this week, i will be putting on my V&H BSS. Do you have numbers for this set up. Do you think i will need to get the 25 degree injectors also.
thewholehog
Exhaust System Topics
10-04-2012 10:04 PM
NEONNIGHT34609
17
01-23-2007 11:28 PM
chapds
11-06-2006 01:53 AM
