tank swap no gas gauge
hey all. i got a probably silly question which im sure can be answered pretty easy, but just thought id check and see. i just did a tank and fender swap on my 08 fat bob, got everything back together just fine (i think). The only thing that isnt back together are the wires leading from my gas gauge, the gauge isnt hooked up and of course the empty light stays on, i had a couple wires break in the process of trying to get them out of the connector intact, to reinstall after taking the gauge out. Basically now, the bike doesnt start after putting some gas in, just sputters n dies, im assuming the gas gauge is the reason here, i was just going to move it to my shed and thought it would still run. Im headed to the local hd for the new connector end tomorrow but thought Id ask just in case, i dont much feel like tearin back into the tank very bad unless i have to.
silly question but couldnt hurt to ask the pros here!
thanks
naz
thanks
naz
i just swapped my tank and the same thing happened although my gas gauge was hooked up... Solution: didnt have "enough" gas in the tank... Youll need at least a half to a full gallon for the pump to prime the first time..
I dont think the fuel gauge not being hooked up has anything to do with it... when you hit the run button can you hear the fuel pump??
I'd vote for more gas.
When I swapped mine, I put about 2 gallons in it. Before I hit the start button, I cycled the fuel pump a few times hoping to get a good prime going. I had to crank it longer than expected, but it did fire up and purr like a kitten...
Since the connectors are giving you problems - you could always bypass them and direct wire/solder/shrink wrap.
well, interesting. I got it runnin topped off the tank, had some gas at home in the gas can and got it running enough to get it to the gas station and top it off. Problem though, its still sputtering and is really, realllllly doggy and unresponsive, backfiring, etc. The pump does come on ok, Im running a dynojet pc V with a big sucker and my vance and hines 2-2, do you guys think i need to remap this again or something needs resetting? Other than that maybe I didnt get something put back in right. Any thoughts? She does run though but sputtery sputtery and dyin.
thanks!
naz
thanks!
naz
im also thinking possibly the gas is just bad, it was filled from the gas jug that i keep for the mower as it was all i had to put in at the time, it was bought last may, although the mower always runs good haha
also thinking a reset on the pcv may be in order, other than that I guess something kinked or not in right inside the tank at this point.
well got it all apart just lookin thru it on the two hoses leading to the black part on the cross over of the tank, ( i know, not the technical terms) i do have a green o ring at the end of one hose connection, but not one in the other. i didnt remember one being there when i took it off, but im betting there are two? i got my service manual out, looking for two on the diagrams
