2001 turn signal conversion?
Old 07-07-2006 | 06:05 PM
intechpc's Avatar
intechpc
1st Gear
Default 2001 turn signal conversion?
Hey guys, I went to the local stealer on lunch today and I was looking at accessories for my '01 FXDX. One thing that caught my eye is they sell a turn signal conversion kit that converts the stock amber signals to red tail/stop/signal lights. Unfortuantely, the label says it fits '02 or later models. Now I've run into similar things with other parts and they've fit my '01. Does anyone know if that conversion kit will fit the 2001? If not does anyone know of a cheaper aftermarket kit that would do the same thing (the Moco kit is only $42 and has complete wiring harnesses). Thanks in advance for the help.
Old 07-07-2006 | 07:01 PM
ReeseSS's Avatar
ReeseSS
Default RE: 2001 turn signal conversion?
Get some cheapie lights that have the 1157 connector, rob the guts and put in current signal, wire second filiment lead to hot brake and respective signal leads at back light.
Old 07-07-2006 | 08:30 PM
mojo's Avatar
mojo
Does your FXDX have the large turn signals still or did you convert them to smaller ones? Just asking because I think I have a set of the smaller ones I bought when I had my FXDX and never installed them. mojo
Old 07-09-2006 | 03:27 PM
intechpc's Avatar
intechpc
1st Gear
I've got the smaller bullet lights, they were relocated when the saddlebags were added. As far as manually converting them, I do know how to do that, but the HD kit would obviously be much easier as it is only a change of the wiring harness and the lenses. I didn't even think about the fact that I'd have to see if the second contact is in there, I'll have to look at that and the harness and if they both look like they're up to the task, maybe just buy the kit and return it if it don't work out.
Old 07-10-2006 | 03:38 PM
SUPER01's Avatar
SUPER01
A word of caution, most places won't take back electrical items that have been opened.
I think the reason they say it won't work is because the 2001 and older used the dome style lens and in 2002 changed to a smaller size. Someone on the forum told me he used it on his 2001 wide glide and it worked fine. I was going to do this but I needed a new tire and brakes first so I spent the $ to keep me on the road.
If you get one let us know if it works.
I have a 2001 Superglide and still have the dome style lights on mine, but as long as it just plugs in I could always pickup some red lenses.
Badbagger
12-31-2019 10:27 AM
stevereno
06-18-2011 01:54 PM
VinnySem
10-08-2010 11:40 AM
Badbagger
11-21-2009 08:47 PM
copout221
07-03-2008 11:30 PM
