Windvest Shield - first impression
I didn't like the height of the sheild that came with it so adquired a Cee Baileys Summer Shield for mine it is shorter and has a wider lower profile..
Here is a link to them http://www.ceebaileys.com/windvest/summer_windvest.html
So, if either one of you guys running the summer shield want a clean as new spare, let me know. No need for me to keep it in a box and never use it.
I very seldom use a windshield, but when I do it's usually during the winter months when riding in colder temperatures, or sometimes during the summer when on long runs (when the bugs are so thick it's impossible to keep your riding glasses clean)..
On my WideGlide I'm running the HD Compact shield that has been cut down to about 1.5" below my normal eye level when riding, as I don't like looking 'through' a windshield. Even cut down the wind (and bugs) are directed over my head and I get very little side buffeting.
Also, I really like the new quick detachable system that replaces the older setup involving the semi-permanent installation of rubber bushings and hairpin type springs which held the shield in place and offered detachability.
The new system uses four die cast steel clamps which have a camming over-center action that securely locks the shield onto the fork tubes between the triple clamps, and is absolutely rock solid.
When the windshield is removed from my WideGlide (which takes only a couple of seconds) there is no 'mounting hardware' left behind on the bike...
But once again, each to their own.....
Here is a picture of the of the newer 'cam over clamping system', and the windshield mounted on the bike.
Exactly. Like so many other things, what works best for one does not for another. I may run the windvest a little longer and decide it's not so great but, for now, it gets my full endorsement (for whatever that is worth LOL). However, for me, the compact quick detach, which is what I had, was definitely not for me for several reasons and I will not be going back to that under any circumstances. It did the job and was easy on and off but it looked way out of place and was too bulky for my dyna, in my opinion. I didn't complain of buffeting at all like others do. I think that has a lot to do with how it is mounted and adjusted with respect to the riders size and expectations. But I'm not noticing any unusual buffeting from the windvest either and it's much smaller. It has an aero-dynamic shape to it that moves the air out of the way without taking up a lot of room. It's not quick detach but it only takes a couple of minutes to put it on or take it off. But I don't need it to be quick detach if it works and looks pretty good at the same time. I'll just consider it winter riding equipment just like my leather jacket. When the weather gets warm, the shield and the jacket get put away.
Well mine is coming off. I actually like the wind when it's warm. I just don't like it when it's cold because it feels like it's blowing right through me no matter what gear I'm wearing.
Is it clear or tinted if its dark tinted I would be....
I'll send you a PM
I once tried an original H-D windshield on my superglide.It was short,i don't remember the type or the hight. BUT it didn't work for me at all! It sent wind on my helmet in a very annoying way...I had to pull over and take it off.
I want to ask does Windvest work better??
I'm 6 ft tall,do i need the 14 or the 16"?
I don't have experience on windshields so any help is welcome
