No start in cold
Old 10-26-2009 | 10:00 PM
BONES206's Avatar
BONES206
The cold oil can be factor. Cold Motor Oil increases drag on moving engine parts and reduces cranking speed.
Old 10-26-2009 | 10:43 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Not the oil. I start my bike when its 30 degrees here with 20w50.
1. Check battery cables (tighten)
2. Check grounding strap (tighten)
3. Remove battery and load test on a motorcycle tester
4. Check VR
5. Check rotor/stator to see if it is charging.
If you need a battery get one from East Penn Deka manufacturing. They make all the HD batteries but their dealer charge less than HD dealers. I saved $40 on mine.
Mborras1
12-12-2018 05:55 PM
junkyardscrounger
General Topics/Tech Tips
02-08-2013 03:35 AM
ninetyzero
11-02-2009 09:59 AM
arkmark
10-09-2009 02:19 PM
RK_Custom
11-16-2007 12:27 PM
