Wide Glide Roll Call
#601
#602
#603
#608
Dyna Roll Call
My '07 FXDWG
Kuruakyn pegs, grips, air cleaner, horn cover, led turn signals
HD switch housings, slotted levers, dash panel, chrome rear peg mounts, diamondback cables, mirrors, turn signal relocation kit, upper & lower belt guards, led taillight, chrome bolt kits used throughout
Headwinds headlight
More to do when I return from Afghanistan!!!
Headwinds headlight
#609
My '07 FXDWG
Headwinds headlight
Headwinds headlight
#610
01 fxdwg
OK heres my 2001 FXDWG. Mod list: Stage 2 Arlen Ness Big Sucker a/c w/ custom K&N intake pipe and filter, 44MM Keihin carb thunderslide, Speed's Stage 3 Big Bore Kit 1450cc to 1550cc : high ( .615" ) lift cams, R&R heads, cylinders, CP pistons and rings, an S&S gear drive, adjustable pushrods, ignition, Screamin' Eagle roller rocker arms, Jims big axle powerglide polished billet aluminum tappet block kit, Staggered chrome Supertrapp Mean Mothers Exhaust, shaved inner primary for belt drive belt clearance,Slammed 2 1/2 in made ridged, Rear axle tensioner chrome covers, Kuryakyn fork brace, Chrome front axle nut covers, Fat Boy rear wheel, Avons, Chrome adjustable mirrors, Chrome slotted wide blade levers Chrome lifter cover, Chrome rocker box, Chrome selenoid cover, Chrome jiffy stand, Chrome Headbolt Cover Kit, Chrome inner crankcase cover, Chrome inner primary cover,and Chrome Physco Chubbys 1 1/4" 8" rise drag bars.
