Last edit by: IB Advertising
Thug Style / Club Style Dyna pic's
http://www.hdforums.com/forum/dyna-g...yna-pic-s.html
ISSUE
Member Lama is in the process of modding his 2007 FXDC into a club style or thug style bike (known today as outlaw bikes) Asks members to provide inspiration and post pictures of their own bikes. Members show off their bikes.
Read below for the full discussion…
ISSUE
#8891
Posting here for all who may be looking for it:
This is what I used.
Harley parts:
Harley parts:
- 59634-06DH FENDER, rear (vivid black) (eBay - used)
- 3022A SCREW (holds base to fender) (HD dealer)
- 7964 NUT (clips onto tab on fender, 3022A screw goes through base into this) (HD dealer)
- 68066-99A BASE ASSEMBLY (stock tail light base assembly for many models) (HD dealer)
- 68026-99 SCREW (2) holds light to base. (HD dealer)
- 68770-02B HARNESS ASSEMBLY (replaces stock wire harness. connects under seat, adhesive backing to stick it to the underside of the fender and runs to the tail light base) (HD dealer)
- Custom Dynamics Black LED Integrated Laydown Taillight w/ Turn Signals & Window (P/N: GEN2I-LDW-S-B) (eBay)
- Kuryakyn Curved Laydown License Plate Frame (P/N: 9171 Chrome, 3148 Black) (eBay)
#8892
I modified the tail light opening in my fender on my '89 and welded in the threaded piece like on the late model fenders.
On the '84 that I'm building right now I'm going to run a BAL tail light on my stock tail light base.
One of my brothers cut and modified a late model Sportster fender to fit his FXR and that worked out well too.
#8894
You'll have to put the late style plug onto your harness and if you want the turn signals to be plug and play, you'll have to install those plugs as well.
It's very simple wiring.
#8895
Going back to the trees, is this too new? http://www.ebay.com/itm/301822538384...%3AMEBIDX%3AIT
#8896
Ok I'm going to attempt it. Guess I'll do the front and the back at the same time! As long as I can figure out what all parts I need.
You won't have the lock tab on that one....
#8897
Those got snatched up anyways haha. How about these? http://www.ebay.com/itm/Harley-David...pVd6xZ&vxp=mtr
Can you tell I'm going as cheap as possible?
#8898
Those are just right.
#8899
Thanks Greezey! Snagged it! I'm going to go ahead and order the taillight too. DO you know what else I'll need to make it work? Is there a harness that turns my stock plug into the late model plugs?
#8900
Good deal! You could get a Dyna tail light harness and then just wire the FXR style plug on the other end, or you could just get the later style plug and install it on your existing tail light harness.
If your existing harness is in good shape, I'd just get the stuff to put the plug on it and not disturb the other end.
