Last edit by: IB Advertising
Thug Style / Club Style Dyna pic's
http://www.hdforums.com/forum/dyna-g...yna-pic-s.html
ISSUE
Member Lama is in the process of modding his 2007 FXDC into a club style or thug style bike (known today as outlaw bikes) Asks members to provide inspiration and post pictures of their own bikes. Members show off their bikes.
Read below for the full discussion…
ISSUE
#5131
There should be kits available for the narrow-glide front end with the eyebrow. On the Ness site I found these:
http://shop.arlenness.com/p-4322-fai...3-up-fxxl.aspx
http://shop.arlenness.com/p-4321-ori...t-for-h-d.aspx
They both claim to be complete kits with mounting hardware, but recommend the use of this headlight bracket:
http://shop.arlenness.com/p-894-head...et-custom.aspx
I would recommend you reach out to them directly to find out what fits, what doesn't and what you need since I've heard a lot of different things about mounting the older style Ness fairings and the use of aftermarket mounts and brackets. I personally have a mid-glide front end so when I had the Ness I was able to buy the mid-glide bolt-on kit and it had everything I needed, but I honestly wasn't happy with the bulbous look of it, and the overall quality, so I have since switched to a Memphis Shades kit. I only bring that up because the mid-glide kit is different than what you need so my experience isn't going to be the same as yours.
I am really leaning towards the HD one as I hear they are a direct bolt on. Price and time is crazy though.
#5132
Awesome. Thanks for the advise. I would love to go with memphis shades however they do not make a 1/4 Fairing that fits an 03. I called and talked to them and they confirmed no fit for 03.
#5133
Love this thread! Love the bikes! Squid's is my favorite but just by a hair (I also might be bias because he's fairly local to me, we both split on the 5 FWY, and he gave me some good advise regarding my plate/turn sig relo).
I'm fairly new to the forum and I've already learned so much. Earlier in this thread there was some conversation about popping and tuners. I'm looking for some tuner advise for my 2014 FXDB. I recently installed a bassani 2:1 (Part # 1D18RB) and a Ness S2 big sucker. I already had the HD Stage 1 download but I knew going into this I would need to have a new tuner installed. My question is: Which one do you recommend?
I'd like to have the flexibility for further modification. I'm not what I would consider "well versed" in this process nor am I very mechanically inclined so if someone with some experience could "dumb it down" for me I'd greatly appreciate it. Based on what I read earlier the PCV sounds like a great option. I'm getting a lot of popping currently (which I expected). If you could also help me out with understanding how much your suggestion will set me back that would be cool..
Last thing.. With the install of the tuner it obviously needs to be tuned. Earlier in this thread someone (I think squid) was talking about sharing maps. If someone shared their map with me (and it ran well) would that eliminate the need to have it professionally tuned (dyno cost, etc..)
Long post.. Sorry
Long post.. Sorry
#5134
Pcv is probably the most popular and we'll supported tuner currently. If you buy it from fuel motorcycle they will ship it with a map for your set up installed and they will support you with free maps for any future upgrades
#5137
Going to reach out to my thread brothers before making a new one...
So I'm eager to change my exhaust and I'm making the order sooner than originally planned, but now that I've put my longer shocks on it seems to be limiting my choices. I do NOT want another short style pipe and most full length pipes look like they'll run right into my lower shock mounts. Thunderheader looks like it'll work, but I wasn't keen on them after reading a lot of bad things in this thread and others. So, to others with a minimum of 13.5 inch shocks, whatcha running for exhaust and did it fit out of the box? Whatever you're running, are you happy with it?
#5138
You can run anything. Just use a spacer on the exhaust bracket (some sort of nut, washer or what have you). I've got my T-header propped out like 1/8 inch with just one washer on the rear and it clears with my 13.5 shocks. It's not the shocks, it's the swingarm.
#5139
Something tells me I'm going to end up going Thunderheader in the end...
#5140
Long post.. Sorry
Long post.. Sorry
I use a Power Vision. It's really well supported by Dynojet, but from what I've read in the Power Vision thread, fuelmoto provides excellent support for it including custom maps.
If you decide on the PV, I'll be happy to share my maps with you, but it has an auto tune feature so you really only need a good base map to start from. Then you just let Auto Tune dial in the map.
http://www.dynojet.com/PowerVision/
